InspireCNC
- Apr 4, 2020
Hello all. Ive been having some problems rigid tapping with the fadal EMC. Lots of broken taps. The first issue was the spindle speed designation of high or low gear. example is "S120.1" or "S120.2" or no setting at all. If the high/low gear waasnt set or ".1" was set, the spindle speed would be off relative to the feedrate. So now im setting the spindle speed with ".2" and the spindle speed when the tap is going in so that problem has been solved. The second problem im having is the feed rate changing when the tap is pulling out. Initially my program included a "P100" dwell time at the bottom of the tap, for some reason this was causing the feedrate to double on pull out and the spindle speed to become unsynchronized. After deleting the "p100" code the feed rate no longer doubled, but stayed the same but still slightly off. My feedrate is 3.75, but would pull out at 3.9. Spindle speed is 120 and thats constant now so no problem there. Attached is a video showing the spindle speed constant at 120, but the Feedrate changing to 3.9 on pulling out. If anybody can see whats wrong with my code or if theres a setting on the machine please let me know, thanks.
Note: im using g84 instead of g84.1, its because the screen set with g84.1 becomes unreadable and the feedrate and spindle speed seems way off.
o6003
N6 G40 G49 G80
N9(Clockwise Tap)
N12 T15 M6
N15 G0 G90 E1 X12.007 Y4.668 S120.2 M5 F3.75
N18 G43 Z0.201 H15
N21 M8
N24 G0 Z0.201
N30 G98 G84 R+0.151 Z-0.549 F3.75 S120.2
N33 G80 Z0.200 F3.75
N36 G1 Z0.201 F3.75
N39 M9
N42 M5
N45 G91 G28 Z0
N48 M30
o6003
N6 G40 G49 G80
N9(Clockwise Tap)
N12 T15 M6
N18 G43 Z0.201 H15
N21 M8
N24 G0 Z0.201
N36 G1 Z0.201 F3.75
N39 M9
N42 M5
N45 G91 G28 Z0
N48 M30
