adamm
Cast Iron
- Sep 19, 2008
- Kingston, ON
Hi Folks,
I have a new-to-me Fadal VMC15 that I'm getting running. It is mostly working, but I'm having trouble with rigid tapping. When it is in the rigid tap cycle (G84.1), the spindle motor oscillates instead of turning smoothly, and the load meter pegs (which isn't surprising given the motor is changing direction quickly and frequently). When I run a non-rigid tapping cycle (G84) it runs as expected.
The machine has a Yaskawa G7 drive that has a sticker on the front with Fadal P/N: INV-0083. I probed the encoder wires at the 9 pin connector just outside of the drive, and the signal looks correct to me. A bit of noise, but it seems reasonable to me (but perhaps that is the problem).
Mechanically, everything seems to be tight.
Any thoughts on what would cause this behaviour?
Here is the code I was running:
Code:
O0011(DEMO PROGRAM TO TRY M6 RIGID TAP)
G17 G90 G0 X0 Y0 G80
T2 M6 (CENTER DRILL)
G0 S1000 M3 H2 Z5.0
G81 G98 G8 F2. Z4.95
M5 G80
T3 M6 (NO7 DRILL)
G0 S1000 M3 H3 Z5.0
G81 G98 G8 F2. Z4.3
M5 G80
T4M6 (M6X1 TAP)
S1000.2 M5 Z5.0 H4
G84.1 G98 G8 F39.3701 Z4.3 S1000.2
G80 M5
M30
