At work today I borrowed a guys spacers for a manual lathe. They were .375x.5x 2.0" long. They had a hole thru the 3 piece set with wire to keep it attached to the jaws. Anyone know where I can find these. Or did he make these himself?
thanks!
I've always called them "spiders" too.
I made mine out of a hex nut with 3 tapped holes. Every other flat on the OD.
Three cap screws in the tapped holes. Adjust to whatever size you need.
Doesn't work very well on CNC hydraulic chucks though.
No wire, but ...
The bolt and lock nut makes the Z length adjustable.
hoil sir captain maybe i am wrong, but if you replied at my question, i must say that the bolt + nut are inside the yellow circle
i dont understand the purpose of those arms that are outside the yellow circle ... also why are not simetrical ?
kindly !
They also serve to keep it from moving around or flying out during use
The reason that they are asymmetrical is that the larger areas ( or the "blobs" ) are where I placed the magnets into them.
Clear as mud?
I made a similar contraption to Zahnrad. I think I saw a commercial one for sale and said, "Wait, I can make something that will cost me twice as much in time and effort". I took it a step further and made it more complicated by adding the ability to bolt parallels of various heights to it. My motto is; Anything worth doing, is worth overdoing. After all that work the original blocks with the zip ties worked just as well, but I was too classy for zip ties.
Notice
