Fadal RS232 Troubleshooting
Likes Likes:  0
Results 1 to 8 of 8
    Apr 2011
    San Diego
    767
    58
    202
    Default Fadal RS232 Troubleshooting
    I appreciate any insight I can get on a problem I'm having with my Fadal. Thank you in advance.
    1. Replaced memory backup battery (on my 1400-4 board) because the memory was corrupted after the machine being off for about a month.
    2. After replacing the battery, the previously working RS-232 connection to upload programs stopped working. I use FadalNC. For a long time with FadalNC, the auto baudrate detection hasn't worked. Now, the upload doesn't work at all.
    3. I did the loopback test with my loopback connector and by shorting pins 2 and 3. (See video here: Fadal failing RS232 Loopback test? - YouTube) My interpretation of the loopback test is that it has failed. Maybe I'm not doing it correctly. Another possibility is that I did the test correctly but I'm interpreting it wrong and the real problem lies between the machine and FadalNC.
    4. I sent my 1030-1b board to a ITS-CNC. They said they tested it and did not find a problem. They recommended checking the power supplies +12V, 5V, and -12V rails. I did and they were within a few percent of nominal. They recommended I send my 1400-4 and 1040-2A boards in so that they could test all three together. I sent those in, along with the cable that goes from the 1030-1B to the side of the control box (RS-485? connector is included in that cable).
    5. They tested the boards and said that they didn't work at first, but after cleaning some contacts, they worked just fine. They recommended cleaning contacts and trying again. I cleaned the contacts of the boards and the slots on the Fadal with contact cleaner to no avail. Nothing has changed with the loopback test and I still can't upload a program.
    6. Pleading for guidance on PM.
    I'm not sure what to try next, but here are the things I'm considering:
    • Bust out my USB logic analyzer and see if I can see the signals coming from the laptop and look at the loop back signal.
    • Possibly replace the transceiver chip with a socket and a new transceiver chip.
    What am I missing here? I appreciate any help I can get.
    Matt
    Apr 2011
    San Diego
    767
    58
    202
    I think I have made a mistake interpreting the RS-232 test. According to Page 477 of the Fadal Maintenance Manual (Section 14: General Information):
    Quote Originally Posted by Fadal Maintenance Manual P. 477
    • Numbers next to the word TESTING should be changing constantly. If this occurs, the 1030 board has passed the test.
    • The numbers at the end of the other sentences should all be zero. If any numbers appear at the end of these sentences it is an indication that the 1030 board is faulty (assuming the cable was checked in step (2) above). Note: The 1030 is rarely faulty.
    • If the diagnostics test passes, then it is safe to conclude that the VMC is not at fault for a communication problem.
    The loopback test behaves like that even at the end of the cable between the computer and the machine, so the problem must lie somewhere between my USB to RS232 adapter, the laptop, or my setup on the laptop (or ground). More investigating to do I guess.
    Feb 2005
    8,950
    13136
    10309
    Quote Originally Posted by dksoba View Post
    That USB to rs232 thing is a bitch.. Can you get your hands on an older computer that actually has an RS232
    and see if that works.. I played with that a few years ago and said screw it.
    I know the USB to RS232 thing has come up here before.. Maybe try a search or start another thread
    that will grab peoples attention that don't have Fadals... Get some more eyeballs on the problem.
    Jun 2015
    Colorado
    352
    829
    130
    Maybe a stupid question but did any parameters get reset when the battery died?
    Apr 2011
    San Diego
    767
    58
    202
    Quote Originally Posted by Bobw View Post
    Yes, alternative RS232 sources would have helped a lot, but last night I was running a long running job in another machine and it was just short enough that finding another RS232 source would have left the machine sitting around not earning it's keep, so I continued with what I could do.
    Here is what I did:
    • Did a loop back test with my USB->RS232 adapter (http://www.usconverters.com/usb-serial-adapter-xs880). I couldn't get it to work through NCFadal.
    • Tried using a terminal application to do the loopback test. Basically you open up the terminal (I used Putty), set your serial parameters, and open the connection. Once the connection is open, anything you type is echo'd back. I guess if the loopback wasn't working, you wouldn't be able to see what you type. This did not work.
    • Tried unplugging the adapter and replugging back in, still didn't work.
    • I took my USB->RS232 adapter to another computer, installed drivers, and tried the loopback test there. IT WORKED FINE THERE!
    • Went back to the laptop next to my Fadal and tried to do the loopback test again, and low and behold, it worked! I didn't intentionally change anything.
    • Tried sending a program to the Fadal, and NOW the program sends just like it used to.
    I'm totally confused about why it wasn't working before. Obviously, the first big breakthrough was properly interpreting the results of Fadal RS232 diagnostic (loopback) test. The way it shows in my video is exactly how it should be.
    The second breakthrough was seeing some evidence that my USB->RS232 converter works properly. I'm not sure what the problem is, but I have another USB-RS232 connector on the way and I'm exploring other communication options (Maybe Calmotion?).
    Quote Originally Posted by BugRobotics View Post
    This isn't a stupid question. The answer: Yes, all (I think) my parameters reset when the battery died. It wasn't a big deal setting back to their default. The answers are in the inside of the back cover of the pendant.
    Dec 2006
    South Jersey
    121
    116
    29
    When I first got my Fadal I tried for days to get the files to transfer. I ended up borrowing another cable and a line tester from a friend. The tester showed that
    the data was transferring and the program ran fine. When I removed the line tester to return it, the data transfer no longer worked. Picked up my own line tester for about $20 and I was back in business. I'm not sure why it made the difference, but it works.
    J.
    Jul 2004
    Wiggins CO. USA
    1,343
    8
    50
    Have you tried it a second time right after it failed?
    Mine, for some reason - will sometimes (if not more often than not) fail on the very first attempt of the day. Then I hit the button to cycle back through MDI to Command prompt, and try again and it works the rest of the day.
    No idea why... and sometimes it will just work right out of the gate just to perplex me. But thought Id mention. But also, my current install of FadalNC will NOT ever let me save something with the save button. Have tried reinstalling many times. Only way to save something from it is to click close and it will ask if I want to save, say yes, and then it will pop up the save box.
    Wade
    Apr 2011
    San Diego
    767
    58
    202
    I confirmed that the problem was with the computer running FadalNC (not sure precisely the root cause though) and everything works now.
