millNchill
- Dec 9, 2019
Ive got a 1995 Fadal VMC 15 that ive owned for about a year now. Machine runs pretty well, however today it started making a high pitched, sort of whining noise intermittently coming from the spindle area after running at 7k RPM for the past few days. Surface finish is still good and I dont get much reading with an indicator when I push and pull on a tool in the spindle (.001-.0015), so I dont believe its a spindle bearing issue. My best guess is it is coming from the belts and pulleys. It does have some vibration or harmonics going on at higher rpms. Im assuming the teeth on the pulleys are loaded up with belt dust and coolant shmegma? I have noticed a bit of what i assume is belt dust building up near the spindle motor. Maybe the belt is rubbing somewhere?
So my question is, am I on the right track here? Is there anything else I should look for when I remove the sheet metal from the head aside from the obvious? Any tips for cleaning the pulleys? Im definitely not a machine tech so any help and insight would be greatly appreciated.
Just another game of Fix-A-Fadal
