Fadal Spindle RPM defaulting to 2500
Results 1 to 6 of 6
    Apr 2021
    Default Fadal Spindle RPM defaulting to 2500
    Hey Everyone, I've got an issue with a 1999 Fadal 3016 88HS, 10k Spindle. For the life of me I can't figure this one out.
    When I input a spindle command for S9702.1, the belts will change and the spindle will only spin up to 2500. If I go above or below this spindle speed, say 9702.09 or 9702.11, the belts will change to the higher end and I'll get the correct spindle speed. I know this can be avoided by just avoiding the 9702.1 spindle speed, but I'd like to know if anyone else has experience this or might know what's going on.
    I use Fusion for all my CAM and sometimes that's the spindle speed in the program and I miss it, so I'd like to not break any more tools
    Only repairs I've done for spindle related items are replacing the hydraulic idlers that change the belts. They were leaking air and hissing all the time.
    -TJ
    Feb 2005
    9,701
    16499
    11849
    You can't use decimal places on a spindle speed. Whole #'s only.
    The only thing a decimal will do after a spindle speed is to force it
    into gear with X.1 and X.2
    You are forcing the spindle into 1st gear(9702.1), which is limited to 2500rpm.
  3. Likes JearBear liked this post
    Apr 2021
    Quote Originally Posted by Bobw View Post
    Bob, thanks for the response. That makes alot more sense, I figured it wasn't a mechanical problem. I'll see if I can adjust my post processor to not output decimal places for the spindle speed. Otherwise, I'll just keep a better eye out for the spindle speeds in the program.
    Thank you!
    Dec 2015
    Connecticut
    1,387
    32
    469
    You can assign a spindle speed to a particular tool number in Fusion, and that’s what it will use.
  6. Likes JearBear liked this post
  7. #5
    Feb 2005
    9,701
    16499
    11849
    Quote Originally Posted by JearBear View Post
    Thank you!
    Forcing into a gear is kind of handy if you are running small tools at lower RPMs, keeps the actual
    motor running slower, and that can keep things a bit quieter. You can use it with your edge finder
    too, you really don't need the torque there. Just tell it 1100.2 or whatever your preferred RPM is.
    Doesn't seem to work on Wye-Delta machines.
  8. Likes JearBear liked this post
  9. #6
    Apr 2021
    Quote Originally Posted by ripperj View Post
    I did not know about that. I will definitely be doing that in the future. Thanks.
