Fadal - Tool Numbers greater than 99?
Likes Likes:  0
Results 1 to 2 of 2
    Sep 2018
    Michigan
    25
    Default Fadal - Tool Numbers greater than 99?
    As many of you know, the tool table on older FADAL controls only goes up to 99. In order to program and machine quickly, I like to buy as many holders and possible and leave tools set up. This is soon going to be a problem for me, as I will have more than 100 tools and only 99 tool offsets. Has anybody run into this problem? Is there an easy solution?
    The only thing I can think of is to use a dedicated Tool number and change it using g10, storing offsets over 99 in your cam program rather than in the machine.
    Is there any other way around this?
    Sep 2018
    Michigan
    25
    Basically what I was thinking would be this
    T155M6 (call for swap tool - or put it in a turret position - that doesn't really matter)
    (Send new length offset value to machine - in this case H22 is dedicated to this
    G90 G10 L10 P22 R0 -15.000
    H22 Z0.1000 (any z move for tools over 99 are set using H value from 22)
    (if a different tool over 99 is called - the G90 G10 must be re-sent)
    Is there a better way to do it then this?
