Collect.Create
- Jun 17, 2021
please excuse me if this is in the wrong thread, Im new to posting around here.
I have a fadal vmc 4020 (906-1) we are doing a spindle rebuild on.
we have to change out the pulley on spindle side (part # pul-0018)
due to the indexing seat being worn and the solenoid not being able to engage the bearing without manual assistance.
Problem #1:
i cannot find the part pul-0018 anywhere. especially that ships to canada. Ive been told that pul-0020N would work by a parts supplier here but when the part came in it has a few different dimensions that concern me, this part is for a thru coolant spindle which mine is not. my question is will this part work? if not is there a parts supplier someone can point to toward?
Problem #2:
on the panel, i have issues with the feed and rapid knobs, feed stays 100% even when trying to toggle, rapid stays 100% also when trying to toggle. As you can imagine this is a nightmare for first off parts and i have to alter programming a little to put in safe guards to avoid a possible catastrophe. how do i go about fixing this issue?
Thanks for your time, any help/insight is greatly appreciated.
-W
Problem #1:
Problem #2:
-W
