wolfenstien
- Oct 6, 2009
- Maine
I've owned this machine for nearly 3-4 years now I think. Hardly ever used it. Done few single tool longer programs with it. Did a couple small parts with a couple tools. But today was going to be my first real part. Couple hours of run time dozen+ tools. Finally going to see what it can do.
Just got my program finished up and all the tools loaded up and decided I'd cycle through them a bit just to make sure all was well and good. Turns out the machine needs to go both directions with the ATC but will only move CCW.
Example: Tool 1 in the spindle
- Call tool 3 (machine will correctly put tool 1 away and go get tool 3)
- With Tool 3 in the spindle call tool 1. (machine will put tool 3 away and get tool 5)
So its moving the right number of places it just doesn't realize the turret is only turning 1 way.
Note the CW and CCW buttons on the keyboard both turn the turret the same way too and that has always been the case.
Regarding the program I ran in the past with multiple tools $10 says I never reused a tool so it used tool 1,2,3,4,5,6 and never skipped a beat.
Guess I need to hand load this one. (Probably not a bad Idea anyway for a noob like me)
How do I fix though? Swapping Relay K5 and K6 didn't change anything. Fuses F5 and F6 look fine. According to the manual it needs a go command and a reverse command to turn atc backwards. Its obviously not getting the reverse command.
Any guidance would be great.
Thanks again
Thanks again
