Fadal Error
- Dec 16, 2009
- Santa Cruz, CA
I started getting some intermittent inoperative keys on the newish Calmotion keyboard on my 1994 VMC20 on Friday. It was the second day of a bit of a heat wave. Only about 80 degrees, but considerably warmer than it has been.
I started it up yesterday (Monday) and the keyboard was giving me trouble again. Eventually it stopped working completely. I swapped it with the keyboard/1090 board interface assembly from my 4020. I still got intermittent inop keys in the VMC20. I could get the keyboard/1090 from the VMC20 to work in the 4020 though.
I did a few more swaps, including trading 1090 boards. I got the VMC20 to work just long enough to get a job halfway set up. Then it started acting up. I even had the pendant wheel and axis switch start acting up. It got stuck in X-axis jog and coarse mode regardless of the position of the axis or resolution switches. I shut it down and restarted. It worked for a bit, although the T key stopped working and eventually the keyboard stopped working completely.
I have done a few more swaps back and forth to no avail.
One extra annoying thing is that a special slitting saw that I only have one of is stuck in the tool carousel on the VMC20, so I had to reprogram the toolpath for another slitting sawblade to set the job up on my 4020.
Two days down and I'm going crazy. I have called Calmotion and had an ongoing email dialogue with a technician there, but not getting it figured out. The latest thing to try is swapping the 1040 board from the 4020 and to check the cable going out of the 1090 board.
I called FadalCNC, but the tech was out.
I called the local Fadal guy, Eya, but he is out of town. The guy I talked to didn't know enough to help. I was supposed to get a call back from another tech sometime.
