kstone
- Oct 15, 2014
- Olive Branch, MS
1992 Fadal 4020.
All -5C Cards
DC amp/servo
Recently replaced Z BS mount bearings and shims within last year
My Z axis on my Fadal 4020 is the most consistently accurate axis with less than 2tenths error. Today I noticed that after setting the offset to do some engraving the tool was not engaging the material. The depth of cut was only 2thou. I ran this program yesterday with no issues but today I had to increase the tool offset -2 thou to even start making a mark. After the program ran I did some a simple test program with a dial test indicator in the tool holder. Setting zero on the indicator and setting the TL offset at 0. Ran a test program that just drives the Z down to that tool zero. The result was 3tenths error which it returned to every time I ran this simple test program.
After running the test I though maybe my height gauge was out of adjustment. It was not. I then ran a program that I had run yesterday that faces the part. The part had already been faced and remained in the machine overnight so I knew if I had any z axis drift I could stop the program and jog the X over to see if the tool tip was offset the top of the part. It was more than 2 thou above the part. I decreased the facemill offset 2 thou and ran the program which did skim the top of the part. I waited 20min and ran the facing program again. Again I had to lower the tool offset 2thou to get it to skim the top of the part. Im thinking maybe the resolver? I find it strange the test program with the dial test indicator would NOT give the same 2thou error I am seeing when actual cutting program is ran. Before anyone mentions contraction of warm spindle I did have to do this same error correcting procedure this morning with machine cold for the engraving so I am ruling out heat growth at the moment.
All -5C Cards
DC amp/servo
