D.Chambers
- Apr 5, 2020
Hi Everyone,
I am trying to run a program from which I had created in Fusion 360 and posting it out to run on a 3 axis mill using FAGOR 8055 control. I going to give all info in detail with what I am seeing and doing and maybe someone has run into a similar situation here.
- I upload my program to the machine memory and no issues there, everything looks good.
- I set up my parameters in the Simulation and when I select cycle start to run the simulation I get an error that says this across the screen:
"CNC: 1156 Y axis soft limit overrun"
N135 G0 X5.2 Y0.0572
Now, what I dont understand is that in the g code on line N90 it runs through the exact same call out G0 X5.2 Y0.0572, but n error. How come I do not get this call out in that line of g code?
%100001,MX--,
N10 ; 3 AXIS CAL BLOCK SETUP 1
N15 ; T2 D=3 CR=0.031 - ZMIN=-0.125 - FACE MILL
N20 ; T9 D=0.3125 CR=0 TAPER=118DEG - ZMIN=-0.175 - CENTER DRILL
N25 ; T10 D=0.5 CR=0.03 - ZMIN=-0.905 - BULLNOSE END MILL
N30 ; T11 D=0.25 CR=0.125 - ZMIN=-0.1631 - BALL END MILL
N35 ; T12 D=0.25 CR=0 TAPER=118DEG - ZMIN=-1.0001 - DRILL
N40 G90 G94 G17
N45 G70
N50 G53 G0 Z0
N55 ; FACE1
N60 T2
N65 M6
N70 T10
N75 S3183 M3
N80 G54
N85 M8
N90 G0 X5.2 Y0.0572
N95 G43 Z0.6
N100 G0 Z0.2
N105 G18 G3 X4.9 Z-0.1 I-0.3 K0 F39.4
N110 G1 X3.75
N115 X-0.5 F82.8
N120 G17 G2 Y1.5945 I0 J0.7686
N125 G1 X3.75
N130 G18 G2 X4.05 Z0.2 I0 K0.3 F39.4
I have seen some comments about the machine parameters possibly being the reason for it saying this, but there is no way in which this should be outside the machine limits since it is only a small 3"3.25" block that I want to run and test the post.I have the set up in the middle of the table.
FAGOR has nice (older) videos on YouTube on how to do a basic set up with tool offsets and setting up your G54 and I followed all of those. I ran some tool testing programming it from the controller (facemills and endmills) and everything worked great. Now I just need posted programs to work from Fusion and I will be all set up.
Thank you in advance!
Dyson
%100001,MX--,
N40 G90 G94 G17
N45 G70
N50 G53 G0 Z0
N55 ; FACE1
N60 T2
N65 M6
N70 T10
N75 S3183 M3
N80 G54
N85 M8
N90 G0 X5.2 Y0.0572
N95 G43 Z0.6
N100 G0 Z0.2
N110 G1 X3.75
N115 X-0.5 F82.8
N125 G1 X3.75
Dyson
