vettespeed
- Feb 24, 2006
- Seattle
Hi,
Working on a post processor to work for a 5 axis gantry Motion Master router & also a 5 axis gantry DMS router, both have Fagor 8055 controls and using TCP (Tool Center Point).
During B/C rotations, I am often getting servo/following errors. Not surprised as these rotations are currently coded with G0 (rapid) moves and occurring very fast.
I want to slow them down by commanding a G1 and a feed rate. I tried G1 F7000. on the DMS and it worked great, I'm assuming this code is commanding 7000 degrees/minute. When I take this same code to the Motion Master, the rotation(s) still occur way too fast. I must reduce it down to about F100. for the rotation speed to be similar to the DMS commanded at F7000.
I'm assuming there might be a parameter that defines how this rotational feed rate is interpreted. Degrees/minute on one machine vs. maybe inches/minute? I can't seem to find a parameter that defines this however?
Anyone know of a parameter I might check that is likely set differently between the two machines that defines how a rotational feed rate is interpreted?
OR
Any other ideas that could help me resolve my issue still allowing me to use one post processor for both machines?
Thank You
OR
Thank You
