Bryan Turner
- Apr 1, 2016
Hello,
Q: Does anyone have a '97-era Fanuc 0-MC that reads brackets in their macro programs? (not "0i-MC")
I'm "refreshing" my '97 Yang mill with upgraded memory, tool & spindle probes, new vises, etc. I purchased the Renishaw probe macros and when installing them, discovered that my control won't accept brackets: [ ] Every program I read with brackets causes an alarm.
I had previously tested for Macro B by checking some simple programs with "#100 = 1", and copying parameters from system memory (#5000+) into program variables. I verified that I have variables #1-33, #100-#199, and #500-#999 visible in the offsets pages, as well as the "Macro A" and "Macro B" options enabled. As far as I can tell, everything works fine except brackets.
DNC works fine for part programs, so my cable & PC settings should be good to go. I can register programs into memory that have hash-symbols #, parenthesis ( ), and equal signs =.
Could anyone help verify the following questions:
- Do you have a '97-era 0-MC that runs Macro B, with brackets?
- Is there a way to type brackets into the control (to test if it is an RS232 issue, not a control issue)?
- Is there another method for inputting programs, without RS232?
- Is it possible to plug a "full keyboard" (with brackets) into my control in place of the smaller keypad?
- If it is a control limitation, is it possible to swap ROM chips with a later 0-MC model and gain the functionality? (I have a A20B-2000-017 motherboard)
Thanks!
--Bryan
Thanks!
--Bryan
