Hello.
I have problem with mori seiki mill. When doing circle (G3G91I-5), it is too small if feed rate is high. If slow feedrate its ok. Error seems to be quite linear, example with 3000mm/min D10 circle is 0.5mm too small, and with 100mm/min its good. Hole is not oval, its just too small. G61 is enabled (no affect). Backlash checked. Also if i make square with g1 its allways same so feed does not affect on that.
Any parameters related to interpolation or servos which i can adjust? I tried tune acceleration parameters but no affect...
