youngguns3
- Nov 6, 2010
- gainesville ga
Hi all,
I'm kind of stuck here, and wanted to ask if anyone knew what step I should take to continue. I am getting some kind of alarm message, but there are no clues on the screen as to how to fix it. Has anyone experienced this on their machine.
I checked both the emergency stop switch on the panel, and also the door switch, and both work as expected.
It seems to be stuck in emergency stop mode, and when I mash reset, it will not reset. I am including a picture of the screen with this to help show the problem.
I read somewhere where someone said to turn the machine off, then hold the reset button in while powering it back up. Should I try that, or is that a definite no-no?
Thank you in advance,
Bill Gillen
Bill Gillen
