Fanuc 10T-F chamfer with C command?
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Sep 2018
    Ohio
    77
    20
    13
    Default Fanuc 10T-F chamfer with C command?
    I have a 1985 Dawoo Puma 6s that I finally have up and running. I am trying to get it to chamfer corners or radius and am lost on what I am missing. I have posted what I wrote hoping someone can tell me what I'm missing. In this one I am trying a .01 rad. I found a M code for M76 and M77 for chamfering. I have tried inserting m76 and 77s also with C for chamfering but still cant get it to work. Any help would be greatly appreciated
    Sent from my SM-G950U using Tapatalk
    Jan 2014
    Washington
    5,191
    933
    2816
    Chamfer and radius by C and R is an option that may not be active on your machine. What is the content of your parameter 9103? In any case the C or R is preceded by a comma. ie ,R.01
    Pretty sure the M codes you listed are for chamfering at the lead out of threading.
  3. Likes Booze Daily, tobydbaker74 liked this post
    Dec 2018
    133
    330
    42
    Chamfering with C command is an option. A lot of people don't realize that not all machines were setup the same even though they all have Fanuc controllers. A lot of it depends how much the factory guy and the buyer of the new machine knew at the time of installation/setup.
    What is the tool nose radius? If it's the usual .031" then it goes like this
    G1 Z0.0
    X0.388
    G3 X0.47 Z-0.041 R0.041
  5. Likes tobydbaker74 liked this post
  6. #4
    Nov 2014
    68
    10
    36
    For a chamfer try...
    G1Z0F.002
    G1 X1.00 C-.01(Make sure there is a G1 and that C value is in direction of travel)
  7. Likes tobydbaker74 liked this post
  8. #5
    Jul 2006
    Arizona
    4,713
    18693
    4558
    Not sure why but some Fanuc machines chamfering was designated as K and not C.
  9. Likes tobydbaker74 liked this post
  10. #6
    Jan 2014
    Washington
    5,191
    933
    2816
    Quote Originally Posted by Philabuster View Post
    Don't recall the exact details, but I or K, positive or negative could be used for chamfering. Something to do with major axis and direction. Have to dig out a programming manual and refresh.
  11. Likes tobydbaker74 liked this post
  12. #7
    Aug 2016
    UNITED KINGDOM
    104
    18
    30
    I think it is I & K for chamfers & R for radii
    N10 G00 X200.0 Z3.0
    N20 G01 Z0.0 F0.3
    N30 Z-30.0 R5.0 (PUTS A 5MM RAD IN THE CORNER.)
    N40 X220.0
    N10 G00 X200.0 Z3.0
    N20 G01 Z0.0 F0.3
    N30 X220.0 K-5.0 (PUTS A 5MM CHAMFER ON THE 220 DIA)
    N40 Z-40.0
    The move with the C or I or K has to be a single axis move.
    the move after has to be perpendicular to that move.
    The mode has to be G01
    There can't be anything between the N30 & N40 blocks, not even a EOB. (I think).
  13. Likes tobydbaker74 liked this post
  14. #8
    Jun 2019
    Kentucky
    51
    For the chamfers just trig it. For the radius, g02 or g03 with an R. Don’t for get to double the x values where needed.
  15. Likes tobydbaker74 liked this post
  16. #9
    Jun 2012
    Michigan
    5,201
    4774
    3148
    I would say you don't have the option because the line before and after the M77 appear to be fine and would put a .01r on that edge.
    C and R work if you have enough movement before and after the command in the direction of the shape.
  17. Likes tobydbaker74 liked this post
  18. #10
    Jan 2014
    Washington
    5,191
    933
    2816
    OP went AWOL I guess. Asked for parameter info so I could tell him if he has the option or not. Crickets......
  19. #11
    Sep 2018
    Ohio
    77
    20
    13
    I wish I went AWOL today. Would be much less stressful. I make parts for fillers, labelers etc etc. for filling sanitizers. I got called in to make several of the we need it yesterday parts. The money is good but still sucks
    People without common sense constantly try to speed the lines up. It's hard for some too understand there is a max you can run before sh%$ starts failing and breaking. I say for one month run at 100 bottles a minute. Then run your way at 135 for a month and see which way makes more.
    Then back to the lathe. We checked to see it the spindle had run out and it was perfect. Then checked the turret. It was out .430 in the X which I can adjust in the offset I'm guessing but the turret in the Y is out 025. Gotta pull the turret off this one I think. Pretty sure I have to do this to get to the curvic coupler gear and replace the pins. Will know tomorrow when I dig in. I will post pics tomorrow night for anyone else that has the issue with the same turret.
  20. #12
    Sep 2018
    Ohio
    77
    20
    13
    I didnt know I had any new post on this till I sat down fo finally eat lunch at 10pm tonight. Some how my notifications for tapatalk got turned off. I will check the oprion parameters tomorrow when I get back in the shop. Thanks for replying this sight has given me a ton of knowledge over the years.
  21. #13
    Sep 2018
    Ohio
    77
    20
    13
    Parameter 9103 is 0 0 0 0 0 1 0 0
  22. #14
    Aug 2016
    UNITED KINGDOM
    104
    18
    30
    Dug out the manual.
    Parameter 9103 on our puma 12L with fanuc 10TF is the same as yours
    00000100
  23. #15
    Jan 2014
    Washington
    5,191
    933
    2816
    The state of 9103 indicates the option was spec'd on the control.
    If you are not using tool nose radius compensation (G41 and G42) then you will need to to add the tool radius (r) to your desired R amount for outside corners and subtract r from R on inside corners For chamfers compensate similarly with .59r to the desired chamfer amount. If you are using G41 and G42 then no adjustment to the R or C values is needed.
  24. Likes barratt liked this post
  25. #16
    Sep 2018
    Ohio
    77
    20
    13
    Well hoping the turret is ok we need to find these locator pins for the tool holder. The previous owner has wrecked all 12 at some point. Any idea where to get them?? They are 15mmOD X 12mm long
  26. #17
    Feb 2014
    FL
    3,436
    11712
    3941
    Quote Originally Posted by tobydbaker74 View Post
    Well hoping the turret is ok we need to find these locator pins for the tool holder. The previous owner has wrecked all 12 at some point. Any idea where to get them?? They are 15mmOD X 12mm long[IMG]https://uploads.tapatalk-cdn.com/20200408/d2c6b146c757ee80642652430d801497.jpg
    Know anybody with a lathe?
  27. Likes tobydbaker74 liked this post
  28. #18
    Sep 2018
    Ohio
    77
    20
    13
    Quote Originally Posted by TeachMePlease View Post
    That made me pee my pants a little In my old age.
  29. #19
    Sep 2018
    Ohio
    77
    20
    13
    Ended up having to pull the turret. For anyone that ever needs to pull one of these run 2 bolts and it will come straight off.
  30. #20
    Sep 2018
    Ohio
    77
    20
    13
    Found a lathe!
  31. Likes TeachMePlease liked this post
