Fanuc 10t lathe control won't reverse the spindle in a tapping program
DMSentra
Cast Iron
Sep 12, 2008
Eugene Oregon
Lots of tapping on 3 lathes at my old work, first time on this one.
N30T800G40
N40G50S200M41
N50G97S150M4(FORWARD ON THIS LATHE)
N60G0G54X0T.2T808
N70G1Z-2.F.0625
N80M5
N90G1Z.2M3
stops the spindle and feeds back out. Using a M0 instead stops and freezes the program. Including G97 and S150 in the N90 line changes nothing. No difference with OPT STOP on or off. No difference with SINGLE STOP on or off.
Some code I don't know about that is particular to this control?
N30T800G40
N40G50S200M41
N60G0G54X0T.2T808
N70G1Z-2.F.0625
N80M5
N90G1Z.2M3
Is the T.2 a typo?
No X pull out.
G0 X0 Z.2
G32 Z-2. F.0625
Z.2 M3
Brent
Is the T.2 a typo?
No X pull out.
G0 X0 Z.2
G32 Z-2. F.0625
Z.2 M3
Brent
Yes, was supposed to be Z.2, and I didn't include the rest of the program with the Z pullout.
Like I asked before, doesn't G32 include an X pullout to clear the thread when returning to Z start postition?
I'm running a part that gets tapped 1/2-13 now. Fanuc 0i-T control
G0 X0 Z.5
G32 Z-1.35 F.076923
Z.5 M4
Is the exact code I'm using. Only reason I use G32 to tap is because G32 disables the feed and spindle overrides.
Brent
G0 X0 Z.5
G32 Z-1.35 F.076923
Z.5 M4
Brent
Gracias. I'll give it to her in the morning and see what she does with it.
N30T800G40
N40G50S200M41
N60G0G54X0T.2T808
N70G1Z-2.F.0625
N80M5
N90G1Z.2M3
Try M3 followed by G01 in two separate blocks.
G0 X0 Z.5
G32 Z-1.35 F.076923
Z.5 M4
Brent
No go. Mine is actually M4 for righthand and M3 for reverse/lefthand, but the spindle continues forward after the turnaround.
What happens if you were to run the following program? Does the spindle alternate in direction?
G97 S500 M04
G04 X1.0
M03
G04 X1.0
/M99
M30
Run it with Block Delete Off until you want to end the program.
Regards,
Bill
G0 X0 Z.5
G32 Z-1.35 F.076923
Z.5 M4
Brent
Manual states M3 and M4 can't follow each other without an interupter so I added an M5 line between. Everything stops and won't start again then.
G97 S500 M04
G04 X1.0
M03
G04 X1.0
/M99
M30
Regards,
Bill
Continues to run M4 with no changes or movement.
Is this a live tool lathe? Is there an M-code to select the main spindle rather than the live tool spindle that needs to be commanded?
You should definitely be able to tap with the main spindle.
I see in the original code you posted that there is a M41. Is that high gear? If so, what happens if you try tapping in low gear? Same deal?
