Fanuc 10T program (file) transfers
Likes Likes:  0
Results 1 to 3 of 3
    Nov 2019
    Michigan
    Default Fanuc 10T program (file) transfers
    Hi, we solved this over a year ago, and Swore we wouldn't forget how (HA!).
    We need our 10T to send / receive programs (files) over the serial RS-232 port.
    We "think" the parameters are well set (we didn't change any since it worked).
    But None of us can remember / decipher the manual as how to navigate the on-screen menus.
    We 'mem something like "mode X, screen buttons Y, mode Z, screen buttons A".
    But the references are to a paper tape(!!) or the cassette tape(!), nothing about RS-232.
    With hat in hand, I request a "cookbook" procedure for up & down loads.
    The PC end is well known - we have 3 Fadals that we do this with regularly.
    The Fanuc has been rarely used, but Mgt has a new category of parts they want us to make.
    The Fanuc/Daewoo lathe is perfectly suited for this.
    Thanks in advance for your consideration. Kevin S.
    Sep 2006
    SW Wisconsin
    508
    19
    127
    On my 3T which is older it is :
    EDIT mode
    Oxxx prog number
    INPUT or NEW LINE
    send from computer serial port to your machine.
    Ed.
    Nov 2019
    Michigan
    Thanks for the reply. We were Vastly overthinking this.
    Another hour or 2 of tinkering and we had all relevant procedures documented.
    Once we figured out how to check / set the 511x registers for RS-232 it was all downhill.
    Thanks again <<<)))
