dandrummerman21
Stainless
- Feb 5, 2008
- MI, USA
Kitamura h400 (1998) with 15mb control.
I want to change a keep relay K7.7 to a 1 in the middle of a program. I noticed that there is G10.1 CNC Command to PMC available.
As far as I can tell, I can change PMC side stuff with this command... or at least, it is possible somehow.
One 15m operators manual that I downloaded says the following:
21.CNC COMMAND TO PMC (G10.1)
The G10.1 command transfers the data to the PMC.
Format
G10.1 P__R__L__;
The data transferred with addresses P, R, and L can be read in the read procedure of the PMC. For details,
refer to the manual supplied by the machine tool builder.
Now, I don't see anything about it in the kitamura manual, but that isn't surprising because there is a lot of stuff not included in there. We have combed the ladder and manual, haven't seen anything related to this. I was wondering if it was still possible? Do I need to change the channel that the PMC I/O is set to, or do something else? PWE on? Dance around a fire singing a song? I have found no information on how to use this.
I have tried the following:
G10.1 N62007 P11001111
G11
And I have tried a few variations of that trying to use R and L, but I only get PS145 alarm, G10.1 TIME OUT. The response to a G10.1 command was not received from the PMC within the specified time limit.
Google is extremely unhelpful with this. Has nobody used or implemented this since google was a thing?
Format
G10.1 P__R__L__;
G11
