Fanuc 15T Controls
Likes Likes:  0
Results 1 to 3 of 3
    Apr 2015
    20
    9
    Default Fanuc 15T Controls
    I have a 68 inch swing VTL that I'm cutting some large forgings on, but the problem I'm having is when I go to set the tool Geo. offset and it goes above 99.9999 we will say 105.0 where do I put the 5.0001 should I put it in the G54 or the wear offset?
    Dec 2018
    83
    233
    33
    Tool geometry offset is for the tool geometry only. G54 is your work Z zero offset. You can't mix the two together.
    I am confused as what you are trying to do.
    Jun 2019
    Maryland
    214
    34
    if you're control has a g54 but you would have to subtract 5.000 from your other tool offsets. what you might want to try is use ur normal g54 then on that tool add a g10 X 5.000 it should shift it a extra 5 inches in X.
