Fanuc 15TF, Stack Overflow, remote buffer, CNC processor NMI
Results 1 to 12 of 12
    Mar 2014
    FINLAND
    26
    8
    Default Fanuc 15TF, Stack Overflow, remote buffer, CNC processor NMI
    Hello all!
    I recently bought a Takisawa TS-25 3-axis CNC lathe. I've been getting familiar with the machine and have encountered some problems.
    I can contact the machine via CD4A RS-232 port, transfer files, backup parameters, use tape mode and drip feed.
    The machine has a Remote Buffer card and as it has a c-axis with live tools and as I get it, the remote buffer offers faster execution of short G1's as there is no true look ahead in the control and G05.1 doesn't work (inappropriate G-code error)
    Anyway, what happens is that when I put the machine to Tape mode, press cycle start and start transfer from PC, the program starts to 'move' and after a few seconds the hydraulics disengage and Trap 15 error screen comes up and IPL mode appears. That happens without a re-boot and the machine starts up normally after power cycle. If I do this with wrong stop bit setting for example, control doesn't crash.
    Error leds seem to be like on this one: https://www.*******.com/forums/fanuc...tml#post823937 and the remote buffer card ha "waiting command from CNC controller led status.
    And if I try to transfer file from CNC to PC via remote buffer (channel 10), the transfer doesn't start and the control pretty much hangs and only way to reset it is by power cycle. If I try to punch parameters via channel 10 (Remote Buffer), the punch starts but after about 1s, hydraulics turn off, control hangs completely and nothing is transferred.
    Initially the status was that parameter punch crashed the control but nothing happened in tape mode or when trying to transfer the software. I suspected that the CD4 UART chips where gone and replaced them and only after that I managed to experience the Trap 15 issue.
    Please find the parameter list below. Seems I can't have the list I pulled out from the machine a couple days ago with current comm settings, I can get proper list if needed, but don't think it's a comm issue.
    Any help is greatly appreciated!
    Code:
    &FWPARAMETER        :%
    N0P00001000
    N3P00000000
    N10P00000000
    N11P00000011
    N12A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N20P1
    N21P1
    N22P1
    N23P1
    N31P1000
    N32P10
    N100P1494889
    N101P28224
    N102P310020
    N103P54384
    N104P183642
    N105P0
    N106P0
    N107P80375
    N108P0
    N109P0
    N1000P00000001
    N1001P00000000
    N1002P00000000
    N1004A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N1005A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N1006A1P00001000A2P00000000A3P00000111A4P00000000A5P00000000A6P00000000
    N1007A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N1008A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N1009A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N1020A1P88A2P90A3P67A4P0A5P0A6P0
    N1021A1P0A2P0A3P0A4P0A5P0A6P0
    N1022A1P1A2P3A3P0A4P0A5P0A6P0
    N1023A1P1A2P2A3P3A4P0A5P0A6P0
    N1024A1P0A2P0A3P0A4P0A5P0A6P0
    N1025A1P0A2P0A3P0A4P0A5P0A6P0
    N1030P0
    N1031P1
    N1032P1
    N1033P3
    N1034P0
    N1035P0
    N1036P0
    N1050P0
    N1051P0
    N1052P0
    N1053P0
    N1054P0
    N1055P0
    N1056P0
    N1057P0
    N1058P0
    N1059P0
    N1181P00000000
    N1182P0
    N1183P0
    N1184P0
    N1185P0
    N1186P0
    N1187P0
    N1188P0
    N1191P0
    N1192P0
    N1193P0
    N1194P0
    N1195P0
    N1196P0
    N1197A1P0A2P0A3P0A4P0A5P0A6P0
    N1200P00000000
    N1220A1P224775A2P619370A3P0A4P0A5P0A6P0
    N1221A1P0A2P10000A3P0A4P0A5P0A6P0
    N1222A1P0A2P9000A3P0A4P0A5P0A6P0
    N1223A1P0A2P-8500A3P0A4P0A5P0A6P0
    N1224A1P0A2P-26000A3P0A4P0A5P0A6P0
    N1225A1P0A2P-43500A3P0A4P0A5P0A6P0
    N1226A1P0A2P-61000A3P0A4P0A5P0A6P0
    N1240A1P0A2P0A3P0A4P0A5P0A6P0
    N1241A1P0A2P0A3P0A4P0A5P0A6P0
    N1242A1P0A2P0A3P0A4P0A5P0A6P0
    N1243A1P0A2P0A3P0A4P0A5P0A6P0
    N1244A1P0A2P0A3P0A4P0A5P0A6P0
    N1245A1P0A2P0A3P0A4P0A5P0A6P0
    N1260A1P0A2P0A3P360000A4P0A5P0A6P0
    N1400P00010010
    N1401P00000000
    N1402P00000000
    N1403P00000000
    N1410P500
    N1411P0
    N1412P25
    N1413P0
    N1414P100
    N1417P0
    N1420A1P1200A2P1600A3P576A4P0A5P0A6P0
    N1421A1P400A2P400A3P400A4P0A5P0A6P0
    N1422A1P600A2P600A3P600A4P0A5P0A6P0
    N1423A1P500A2P500A3P500A4P0A5P0A6P0
    N1424A1P0A2P0A3P0A4P0A5P0A6P0
    N1425A1P200A2P200A3P200A4P0A5P0A6P0
    N1426P0
    N1427A1P0A2P0A3P0A4P0A5P0A6P0
    N1428P0
    N1471A1P0A2P0A3P0A4P0A5P0A6P0
    N1472A1P0A2P0A3P0A4P0A5P0A6P0
    N1478A1P0A2P0A3P0A4P0A5P0A6P0
    N1479A1P0A2P0A3P0A4P0A5P0A6P0
    N1480A1P0A2P0A3P0A4P0A5P0A6P0
    N1481A1P0A2P0A3P0A4P0A5P0A6P0
    N1482A1P0A2P0A3P0A4P0A5P0A6P0
    N1493P0
    N1496P0
    N1497P0
    N1498P0
    N1499A1P0A2P0A3P0A4P0A5P0A6P0
    N1600A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N1601P00000000
    N1620A1P80A2P140A3P100A4P0A5P0A6P0
    N1621A1P200A2P200A3P200A4P0A5P0A6P0
    N1622A1P0A2P0A3P0A4P0A5P0A6P0
    N1623A1P0A2P0A3P0A4P0A5P0A6P0
    N1624A1P50A2P50A3P50A4P0A5P0A6P0
    N1625A1P0A2P0A3P0A4P0A5P0A6P0
    N1626A1P80A2P0A3P80A4P0A5P0A6P0
    N1627A1P800A2P800A3P800A4P0A5P0A6P0
    N1628A1P0A2P0A3P0A4P0A5P0A6P0
    N1629A1P0A2P0A3P0A4P0A5P0A6P0
    N1630P0
    N1631P0
    N1633P0
    N1634P0
    N1635A1P0A2P0A3P0A4P0A5P0A6P0
    N1643A1P0A2P0A3P0A4P0A5P0A6P0
    N1644A1P0A2P0A3P0A4P0A5P0A6P0
    N1645A1P0A2P0A3P0A4P0A5P0A6P0
    N1646P0
    N1647P0
    N1648P0
    N1800P00000110
    N1802A1P00000000A2P00000000A3P00000010A4P00000000A5P00000000A6P00000000
    N1803A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N1804A1P00000010A2P00000010A3P00000010A4P00000000A5P00000000A6P00000000
    N1805A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N1806A1P00011010A2P00011111A3P00001001A4P00000000A5P00000000A6P00000000
    N1807A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N1808A1P00001000A2P00001000A3P00001000A4P00000000A5P00000000A6P00000000
    N1809A1P01000110A2P01000110A3P01000110A4P00000000A5P00000000A6P00000000
    N1810P00100000
    N1811P00000000
    N1815A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N1816A1P00110100A2P01110111A3P00000010A4P00000000A5P00000000A6P00000000
    N1817A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N1820A1P2A2P2A3P2A4P0A5P0A6P0
    N1821A1P0A2P0A3P0A4P0A5P0A6P0
    N1822A1P0A2P0A3P0A4P0A5P0A6P0
    N1825A1P3000A2P3000A3P3000A4P0A5P0A6P0
    N1826A1P0A2P0A3P0A4P0A5P0A6P0
    N1827A1P300A2P300A3P20A4P0A5P0A6P0
    N1828A1P20000A2P14000A3P5000A4P0A5P0A6P0
    N1829A1P100A2P100A3P100A4P0A5P0A6P0
    N1830A1P100A2P100A3P100A4P0A5P0A6P0
    N1831A1P0A2P0A3P0A4P0A5P0A6P0
    N1832A1P17000A2P11500A3P4300A4P0A5P0A6P0
    N1833A1P0A2P0A3P0A4P0A5P0A6P0
    N1834A1P0A2P0A3P0A4P0A5P0A6P0
    N1835A1P0A2P0A3P0A4P0A5P0A6P0
    N1837A1P0A2P0A3P0A4P0A5P0A6P0
    N1838A1P0A2P0A3P0A4P0A5P0A6P0
    N1849A1P0A2P0A3P0A4P0A5P0A6P0
    N1850A1P4055A2P2647A3P0A4P0A5P0A6P0
    N1851A1P10A2P0A3P0A4P0A5P0A6P0
    N1852A1P672A2P1090A3P1170A4P0A5P0A6P0
    N1853A1P-1574A2P-2360A3P-2289A4P0A5P0A6P0
    N1854A1P-2526A2P-2625A3P-2485A4P0A5P0A6P0
    N1855A1P136A2P287A3P27A4P0A5P0A6P0
    N1856A1P-1215A2P-2571A3P-244A4P0A5P0A6P0
    N1857A1P0A2P0A3P0A4P0A5P0A6P0
    N1858A1P-8235A2P-8235A3P-8235A4P0A5P0A6P0
    N1859A1P3124A2P1476A3P15580A4P0A5P0A6P0
    N1860A1P0A2P0A3P0A4P0A5P0A6P0
    N1861A1P0A2P0A3P0A4P0A5P0A6P0
    N1862A1P956A2P956A3P956A4P0A5P0A6P0
    N1863A1P510A2P510A3P510A4P0A5P0A6P0
    N1864A1P0A2P0A3P0A4P0A5P0A6P0
    N1865A1P21A2P21A3P70A4P0A5P0A6P0
    N1866A1P3787A2P3787A3P1136A4P0A5P0A6P0
    N1867A1P319A2P319A3P319A4P0A5P0A6P0
    N1868A1P2520A2P3780A3P644A4P0A5P0A6P0
    N1869A1P2330A2P2330A3P559A4P0A5P0A6P0
    N1870A1P57A2P57A3P46A4P0A5P0A6P0
    N1871A1P5A2P5A3P0A4P0A5P0A6P0
    N1872A1P7282A2P7282A3P7282A4P0A5P0A6P0
    N1873A1P120A2P120A3P120A4P0A5P0A6P0
    N1874A1P64A2P65A3P46A4P0A5P0A6P0
    N1875A1P88A2P143A3P18A4P0A5P0A6P0
    N1876A1P10000A2P8000A3P12000A4P0A5P0A6P0
    N1877A1P32694A2P32578A3P32627A4P0A5P0A6P0
    N1878A1P924A2P2381A3P1766A4P0A5P0A6P0
    N1879A1P111A2P-111A3P111A4P0A5P0A6P0
    N1880P0
    N1881P0
    N1882P0
    N1883A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N1884A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N1890A1P-20A2P-20A3P-20A4P0A5P0A6P0
    N1891A1P10000A2P8000A3P12000A4P0A5P0A6P0
    N1892A1P4A2P4A3P4A4P0A5P0A6P0
    N1893A1P2740A2P7075A3P5245A4P0A5P0A6P0
    N1894A1P0A2P0A3P0A4P0A5P0A6P0
    N1895A1P0A2P0A3P0A4P0A5P0A6P0
    N1896A1P0A2P0A3P0A4P0A5P0A6P0
    N1910P0
    N1912A1P0A2P0A3P0A4P0A5P0A6P0
    N1913A1P0A2P0A3P0A4P0A5P0A6P0
    N1914A1P0A2P0A3P0A4P0A5P0A6P0
    N1915A1P0A2P0A3P0A4P0A5P0A6P0
    N1916A1P0A2P0A3P0A4P0A5P0A6P0
    N1920A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N1921A1P0A2P0A3P0A4P0A5P0A6P0
    N1922A1P0A2P0A3P0A4P0A5P0A6P0
    N1923A1P0A2P0A3P0A4P0A5P0A6P0
    N1924A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N1925A1P0A2P0A3P0A4P0A5P0A6P0
    N1926A1P0A2P0A3P0A4P0A5P0A6P0
    N1930A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N1931A1P0A2P0A3P0A4P0A5P0A6P0
    N1932A1P0A2P0A3P0A4P0A5P0A6P0
    N1933A1P0A2P0A3P0A4P0A5P0A6P0
    N1934A1P0A2P0A3P0A4P0A5P0A6P0
    N1935A1P0A2P0A3P0A4P0A5P0A6P0
    N1936A1P0A2P0A3P0A4P0A5P0A6P0
    N1940A1P0A2P0A3P0A4P0A5P0A6P0
    N1941A1P0A2P0A3P0A4P0A5P0A6P0
    N1942A1P0A2P0A3P0A4P0A5P0A6P0
    N1943A1P0A2P0A3P0A4P0A5P0A6P0
    N1944A1P0A2P0A3P0A4P0A5P0A6P0
    N1945A1P0A2P0A3P0A4P0A5P0A6P0
    N1946A1P0A2P0A3P0A4P0A5P0A6P0
    N1947A1P0A2P0A3P0A4P0A5P0A6P0
    N1948A1P0A2P0A3P0A4P0A5P0A6P0
    N1949A1P0A2P0A3P0A4P0A5P0A6P0
    N1950A1P0A2P0A3P0A4P0A5P0A6P0
    N1951A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N1952A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N1953A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N1954A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N1955A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N1956A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N1961A1P0A2P0A3P0A4P0A5P0A6P0
    N1962A1P0A2P0A3P0A4P0A5P0A6P0
    N1963A1P0A2P0A3P0A4P0A5P0A6P0
    N1964A1P0A2P0A3P0A4P0A5P0A6P0
    N1965A1P0A2P0A3P0A4P0A5P0A6P0
    N1966A1P0A2P0A3P0A4P0A5P0A6P0
    N1967A1P2100A2P2520A3P0A4P0A5P0A6P0
    N1968A1P0A2P0A3P0A4P0A5P0A6P0
    N1969A1P0A2P0A3P0A4P0A5P0A6P0
    N1970A1P0A2P0A3P0A4P0A5P0A6P0
    N1971A1P0A2P0A3P0A4P0A5P0A6P0
    N1972A1P0A2P0A3P0A4P0A5P0A6P0
    N1973A1P0A2P0A3P0A4P0A5P0A6P0
    N1974A1P0A2P0A3P0A4P0A5P0A6P0
    N1975A1P0A2P0A3P0A4P0A5P0A6P0
    N1976A1P0A2P0A3P0A4P0A5P0A6P0
    N1977A1P0A2P0A3P3A4P0A5P0A6P0
    N1978A1P0A2P0A3P40A4P0A5P0A6P0
    N1979A1P1353A2P2175A3P1872A4P0A5P0A6P0
    N1980A1P0A2P0A3P0A4P0A5P0A6P0
    N1981A1P0A2P0A3P0A4P0A5P0A6P0
    N1982A1P0A2P0A3P0A4P0A5P0A6P0
    N1983A1P0A2P0A3P0A4P0A5P0A6P0
    N1984A1P0A2P0A3P0A4P0A5P0A6P0
    N1985A1P0A2P0A3P0A4P0A5P0A6P0
    N1986A1P0A2P0A3P0A4P0A5P0A6P0
    N1987A1P0A2P0A3P0A4P0A5P0A6P0
    N1988A1P0A2P0A3P0A4P0A5P0A6P0
    N1989A1P0A2P0A3P0A4P0A5P0A6P0
    N1990A1P0A2P0A3P0A4P0A5P0A6P0
    N1991A1P0A2P0A3P0A4P0A5P0A6P0
    N2000P00000000
    N2001P00000000
    N2002P00000000
    N2003P00000000
    N2004P00000000
    N2005P00000000
    N2010P64
    N2011P64
    N2012P0
    N2013P0
    N2014P1000
    N2015P1000
    N2016P25200
    N2020A1P0A2P0A3P0A4P0A5P0A6P0
    N2021A1P0A2P0A3P0A4P0A5P0A6P0
    N2030P2
    N2031P4
    N2032P4
    N2033P0
    N2034P0
    N2035P0
    N2036P0
    N2037P0
    N2049P0
    N2051P0
    N2052P0
    N2053P0
    N2200P00011000
    N2201P00000011
    N2202P00000100
    N2203P00000110
    N2204P00000000
    N2205P00000100
    N2206P00000000
    N2207P00000000
    N2208P00000000
    N2209P00000000
    N2220P0
    N2221P0
    N2222P0
    N2223P0
    N2224P0
    N2225P0
    N2226P0
    N2227P0
    N2228P0
    N2229P0
    N2231P1
    N2232P2
    N2233P3
    N2234P150
    N2235P155
    N2236P162
    N2237P162
    N2241P0
    N2242P0
    N2243P0
    N2244P0
    N2245P0
    N2258P0
    N2259P0
    N2260P0
    N2261P0
    N2262P0
    N2263A1P0A2P0A3P0A4P0A5P0A6P0
    N2264A1P0A2P0A3P0A4P0A5P0A6P0
    N2265P0
    N2266P0
    N2267P0
    N2268P0
    N2269P0
    N2270P0
    N2271P0
    N2272P0
    N2273P0
    N2274P0
    N2275P0
    N2276P0
    N2277P0
    N2278P0
    N2279P0
    N2280P0
    N2281P0
    N2282P0
    N2283P0
    N2284P0
    N2285P0
    N2292P0
    N2293P0
    N2294P0
    N2295P0
    N2296P0
    N2297P0
    N2298P0
    N2299P0
    N2311P0
    N2312P0
    N2313P0
    N2314P0
    N2315P0
    N2316P0
    N2317P0
    N2318P0
    N2321P0
    N2322P0
    N2323P0
    N2324P0
    N2325P0
    N2326P0
    N2327P0
    N2328P0
    N2331P0
    N2332P0
    N2333P0
    N2334P0
    N2335P0
    N2336P0
    N2337P0
    N2338P0
    N2341P0
    N2342P0
    N2343P0
    N2344P0
    N2345P0
    N2346P0
    N2347P0
    N2348P0
    N2351P0
    N2352P0
    N2353P0
    N2354P0
    N2355P0
    N2356P0
    N2357P0
    N2358P0
    N2361P0
    N2362P0
    N2363P0
    N2364P0
    N2365P0
    N2366P0
    N2367P0
    N2368P0
    N2371P0
    N2372P0
    N2373P0
    N2374P0
    N2375P0
    N2376P0
    N2377P0
    N2378P0
    N2381P0
    N2382P0
    N2383P0
    N2384P0
    N2385P0
    N2386P0
    N2387P0
    N2388P0
    N2390P0
    N2391P0
    N2392P0
    N2393P0
    N2394P0
    N2395P0
    N2396P0
    N2397P0
    N2398P0
    N2399P0
    N2400P00010001
    N2401P10010000
    N2402P00000010
    N2403P00000000
    N2404P00000000
    N2405P00000000
    N2406P00000000
    N2410P1000
    N2411P0
    N2412P0
    N2413P0
    N2414P0
    N2415P0
    N2416P0
    N2417P0
    N2418P0
    N2421P0
    N2422P0
    N2423P0
    N2424P0
    N2425P0
    N2426P0
    N2428P0
    N2431P0
    N2432P0
    N2481P0
    N2482P0
    N2483P0
    N2484P0
    N2503P0
    N2504P0
    N2505P0
    N2506P0
    N2510P0
    N2900P0
    N3000P00000000
    N3001P00000000
    N3002P00000000
    N3003P00000000
    N3004P00000000
    N3005P00000000
    N3006P00000000
    N3007P00000000
    N3008P00000000
    N3009P00000000
    N3010P00000000
    N3011P00000000
    N3012P00000000
    N3013P00000000
    N3014P00000000
    N3015P00000000
    N3016P00000000
    N3017P00000000
    N3018P00000000
    N3019P00000000
    N3020P0
    N3021P0
    N3022P0
    N3023P0
    N3024P0
    N3025P0
    N3026P0
    N3027P0
    N3028P0
    N3029P0
    N3030P0
    N3031P0
    N3032P0
    N3033P0
    N3034P0
    N3035P0
    N3036P0
    N3037P0
    N3038P0
    N3039P0
    N3040P0
    N3041P0
    N3042P0
    N3043P0
    N3044P0
    N3045P0
    N3046P0
    N3047P0
    N3048P0
    N3049P0
    N3050P0
    N3051P0
    N3052P0
    N3053P0
    N3054P0
    N3055P0
    N3056P0
    N3057P0
    N3058P0
    N3059P0
    N3060P0
    N3061P0
    N3062P0
    N3063P0
    N3064P0
    N3065P0
    N3066P0
    N3067P0
    N3068P0
    N3069P0
    N3070P0
    N3071P0
    N3072P0
    N3073P0
    N3074P0
    N3075P0
    N3076P0
    N3077P0
    N3078P0
    N3079P0
    N3080P0
    N3081P0
    N3082P0
    N3083P0
    N3084P0
    N3085P0
    N3086P0
    N3087P0
    N3088P0
    N3089P0
    N3090P0
    N3091P0
    N3092P0
    N3093P0
    N3094P0
    N3095P0
    N3096P0
    N3097P0
    N3098P0
    N3099P0
    N3100P0
    N3101P0
    N3102P0
    N3103P0
    N3104P0
    N3105P0
    N3106P0
    N3107P0
    N3108P0
    N3109P0
    N3110P0
    N3111P0
    N3112P0
    N3113P0
    N3114P0
    N3115P0
    N3116P0
    N3117P0
    N3118P0
    N3119P0
    N3120P0
    N3121P0
    N3122P0
    N3123P0
    N3124P0
    N3125P0
    N3126P0
    N3127P0
    N3128P0
    N3129P0
    N3130P0
    N3131P0
    N3132P0
    N3133P0
    N3134P0
    N3135P0
    N3140P00000000
    N3141P00000000
    N3142P00000000
    N3143P00000000
    N3144P00000000
    N3145P00000000
    N3146P00000000
    N3147P00000000
    N3148P00000000
    N3149P00000000
    N3150P00000000
    N3151P00000000
    N3152P00000000
    N3153P00000000
    N3154P00000000
    N3155P00000000
    N3156P00000000
    N3157P00000000
    N3158P00000000
    N3159P00000000
    N3160P0
    N3161P0
    N3162P0
    N3163P0
    N3164P0
    N3165P0
    N3166P0
    N3167P0
    N3168P0
    N3169P0
    N3170P0
    N3171P0
    N3172P0
    N3173P0
    N3174P0
    N3175P0
    N3176P0
    N3177P0
    N3178P0
    N3179P0
    N3180P0
    N3181P0
    N3182P0
    N3183P0
    N3184P0
    N3185P0
    N3186P0
    N3187P0
    N3188P0
    N3189P0
    N3190P0
    N3191P0
    N3192P0
    N3193P0
    N3194P0
    N3195P0
    N3196P0
    N3197P0
    N3198P0
    N3199P0
    N3200P0
    N3201P0
    N3202P0
    N3203P0
    N3204P0
    N3205P0
    N3206P0
    N3207P0
    N3208P0
    N3209P0
    N3210P0
    N3211P0
    N3212P0
    N3213P0
    N3214P0
    N3215P0
    N3216P0
    N3217P0
    N3218P0
    N3219P0
    N3220P0
    N3221P0
    N3222P0
    N3223P0
    N3224P0
    N3225P0
    N3226P0
    N3227P0
    N3228P0
    N3229P0
    N3230P0
    N3231P0
    N3232P0
    N3233P0
    N3234P0
    N3235P0
    N3236P0
    N3237P0
    N3238P0
    N3239P0
    N3240P0
    N3241P0
    N3242P0
    N3243P0
    N3244P0
    N3245P0
    N3246P0
    N3247P0
    N3248P0
    N3249P0
    N3250P0
    N3251P0
    N3252P0
    N3253P0
    N3254P0
    N3255P0
    N3256P0
    N3257P0
    N3258P0
    N3259P0
    N3260P0
    N3261P0
    N3262P0
    N3263P0
    N3264P0
    N3265P0
    N3266P0
    N3267P0
    N3268P0
    N3269P0
    N3270P0
    N3271P0
    N3272P0
    N3273P0
    N3274P0
    N3275P0
    N3280P0
    N3281P0
    N3282P0
    N3283P0
    N3284P0
    N3285P0
    N3286P0
    N3287P0
    N3288P0
    N3289P0
    N3290P0
    N3291P0
    N3292P0
    N3293P0
    N3294P0
    N3295P0
    N3296P0
    N3297P0
    N3298P0
    N3299P0
    N3300P0
    N3301P0
    N3302P0
    N3303P0
    N3304P0
    N3305P0
    N3306P0
    N3307P0
    N3308P0
    N3309P0
    N3310P0
    N3311P0
    N3312P0
    N3313P0
    N3314P0
    N3315P0
    N3316P0
    N3317P0
    N3318P0
    N3319P0
    N3320P00000000
    N3321P00000000
    N3322P00000000
    N3323P00000000
    N3324P00000000
    N3325P00000000
    N3326P00000000
    N3327P00000000
    N3328P00000000
    N3329P00000000
    N3330P00000000
    N3331P00000000
    N3332P00000000
    N3333P00000000
    N3334P00000000
    N3335P00000000
    N3336P00000000
    N3337P00000000
    N3338P00000000
    N3339P00000000
    N3340P0
    N3341P0
    N3342P0
    N3343P0
    N3344P0
    N3345P0
    N3346P0
    N3347P0
    N3348P0
    N3349P0
    N3350P0
    N3351P0
    N3352P0
    N3353P0
    N3354P0
    N3355P0
    N3356P0
    N3357P0
    N3358P0
    N3359P0
    N3360P0
    N3361P0
    N3362P0
    N3363P0
    N3364P0
    N3365P0
    N3366P0
    N3367P0
    N3368P0
    N3369P0
    N3370P0
    N3371P0
    N3372P0
    N3373P0
    N3374P0
    N3375P0
    N3376P0
    N3377P0
    N3378P0
    N3379P0
    N3380P0
    N3381P0
    N3382P0
    N3383P0
    N3384P0
    N3385P0
    N3386P0
    N3387P0
    N3388P0
    N3389P0
    N3390P0
    N3391P0
    N3392P0
    N3393P0
    N3394P0
    N3395P0
    N3396P0
    N3397P0
    N3398P0
    N3399P0
    N3400P0
    N3401P0
    N3402P0
    N3403P0
    N3404P0
    N3405P0
    N3406P0
    N3407P0
    N3408P0
    N3409P0
    N3410P0
    N3411P0
    N3412P0
    N3413P0
    N3414P0
    N3415P0
    N3416P0
    N3417P0
    N3418P0
    N3419P0
    N3420P0
    N3421P0
    N3422P0
    N3423P0
    N3424P0
    N3425P0
    N3426P0
    N3427P0
    N3428P0
    N3429P0
    N3430P0
    N3431P0
    N3432P0
    N3433P0
    N3434P0
    N3435P0
    N3436P0
    N3437P0
    N3438P0
    N3439P0
    N3440P0
    N3441P0
    N3442P0
    N3443P0
    N3444P0
    N3445P0
    N3446P0
    N3447P0
    N3448P0
    N3449P0
    N3450P0
    N3451P0
    N3452P0
    N3453P0
    N3454P0
    N3455P0
    N3456P0
    N3457P0
    N3458P0
    N3459P0
    N3460P0
    N3461P0
    N3462P0
    N3463P0
    N3464P0
    N3465P0
    N3466P0
    N3467P0
    N3468P0
    N3469P0
    N3470P0
    N3471P0
    N3472P0
    N3473P0
    N3474P0
    N3475P0
    N3476P0
    N3477P0
    N3478P0
    N3479P0
    N3480P0
    N3481P0
    N3482P0
    N3483P0
    N3484P0
    N3485P0
    N3486P0
    N3487P0
    N3488P0
    N3489P0
    N3490P0
    N3491P0
    N3492P0
    N3493P0
    N3494P0
    N3495P0
    N3500P0
    N3501P0
    N3502P0
    N3503P0
    N3504P0
    N3505P0
    N3506P0
    N3507P0
    N3508P0
    N3509P0
    N3510P0
    N3511P0
    N3512P0
    N3513P0
    N3514P0
    N3515P0
    N3516P0
    N3517P0
    N3518P0
    N3519P0
    N3520P0
    N3521P0
    N3522P0
    N3523P0
    N3524P0
    N3525P0
    N3526P0
    N3527P0
    N3528P0
    N3529P0
    N3530P0
    N3531P0
    N3532P0
    N3533P0
    N3534P0
    N3535P0
    N3536P0
    N3537P0
    N3538P0
    N3539P0
    N3540P00000000
    N3541P00000000
    N3542P00000000
    N3543P00000000
    N3544P00000000
    N3545P00000000
    N3546P00000000
    N3547P00000000
    N3548P00000000
    N3549P00000000
    N3550P00000000
    N3551P00000000
    N3552P00000000
    N3553P00000000
    N3554P00000000
    N3555P00000000
    N3556P00000000
    N3557P00000000
    N3558P00000000
    N3559P00000000
    N3560P0
    N3561P0
    N3562P0
    N3563P0
    N3564P0
    N3565P0
    N3566P0
    N3567P0
    N3568P0
    N3569P0
    N3570P0
    N3571P0
    N3572P0
    N3573P0
    N3574P0
    N3575P0
    N3576P0
    N3577P0
    N3578P0
    N3579P0
    N3580P0
    N3581P0
    N3582P0
    N3583P0
    N3584P0
    N3585P0
    N3586P0
    N3587P0
    N3588P0
    N3589P0
    N3590P0
    N3591P0
    N3592P0
    N3593P0
    N3594P0
    N3595P0
    N3596P0
    N3597P0
    N3598P0
    N3599P0
    N3600P0
    N3601P0
    N3602P0
    N3603P0
    N3604P0
    N3605P0
    N3606P0
    N3607P0
    N3608P0
    N3609P0
    N3610P0
    N3611P0
    N3612P0
    N3613P0
    N3614P0
    N3615P0
    N3616P0
    N3617P0
    N3618P0
    N3619P0
    N3620P0
    N3621P0
    N3622P0
    N3623P0
    N3624P0
    N3625P0
    N3626P0
    N3627P0
    N3628P0
    N3629P0
    N3630P0
    N3631P0
    N3632P0
    N3633P0
    N3634P0
    N3635P0
    N3636P0
    N3637P0
    N3638P0
    N3639P0
    N3640P0
    N3641P0
    N3642P0
    N3643P0
    N3644P0
    N3645P0
    N3646P0
    N3647P0
    N3648P0
    N3649P0
    N3650P0
    N3651P0
    N3652P0
    N3653P0
    N3654P0
    N3655P0
    N3656P0
    N3657P0
    N3658P0
    N3659P0
    N3660P0
    N3661P0
    N3662P0
    N3663P0
    N3664P0
    N3665P0
    N3666P0
    N3667P0
    N3668P0
    N3669P0
    N3670P0
    N3671P0
    N3672P0
    N3673P0
    N3674P0
    N3675P0
    N3676P0
    N3677P0
    N3678P0
    N3679P0
    N3680P0
    N3681P0
    N3682P0
    N3683P0
    N3684P0
    N3685P0
    N3686P0
    N3687P0
    N3688P0
    N3689P0
    N3690P0
    N3691P0
    N3692P0
    N3693P0
    N3694P0
    N3695P0
    N3696P0
    N3697P0
    N3698P0
    N3699P0
    N3700P0
    N3701P0
    N3702P0
    N3703P0
    N3704P0
    N3705P0
    N3706P0
    N3707P0
    N3708P0
    N3709P0
    N3710P0
    N3711P0
    N3712P0
    N3713P0
    N3714P0
    N3715P0
    N4600P00000000
    N4610P0
    N4611P0
    N4612P0
    N4615P0
    N4616P0
    N4619P0
    N4620P0
    N4621P0
    N4622P0
    N4623P0
    N4624P0
    N4629P0
    N4630P0
    N4631P0
    N4821P0
    N4822P0
    N4823P0
    N4831P0
    N4832P0
    N4833P0
    N4834P0
    N4835P0
    N4881A1P0A2P0A3P0A4P0A5P0A6P0
    N4882A1P0A2P0A3P0A4P0A5P0A6P0
    N4883A1P0A2P0A3P0A4P0A5P0A6P0
    N5000P00000000
    N5001P1
    N5002P2
    N5003P3
    N5011P0
    N5013P4
    N5050P10
    N5051P10
    N5052P5
    N5053P5
    N5054P256
    N5055P256
    N5056P00001010
    N5057P0
    N5058P0
    N5060P0
    N5061P0
    N5062P0
    N5063P0
    N5064P0
    N5065P0
    N5070P11
    N5071P0
    N5072P0
    N5073P0
    N5074P0
    N5081P8
    N5082P1
    N5083P12
    N5084P1
    N5090P0
    N5091P0
    N5092P0
    N5093P0
    N5094P0
    N5110P8
    N5111P1
    N5112P12
    N5120P0
    N5121P0
    N5122P0
    N5130P0
    N5131P0
    N5132P0
    N5140P6
    N5141P1
    N5142P12
    N5150P0
    N5151P0
    N5152P0
    N5160P0
    N5161P0
    N5162P0
    N5170P0
    N5171P0
    N5172P0
    N5180P0
    N5181P0
    N5182P0
    N5190P0
    N5191P0
    N5192P0
    N5200P10000000
    N5210A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N5220A1P10000A2P5000A3P99999999A4P99999999A5P99999999A6P99999999
    N5221A1P-320000A2P-640000A3P-99999999A4P-99999999A5P-99999999A6P-99999999
    N5222A1P99999999A2P99999999A3P99999999A4P99999999A5P99999999A6P99999999
    N5223A1P99999999A2P99999999A3P-99999999A4P-99999999A5P-99999999A6P-99999999
    N5224A1P99999999A2P99999999A3P99999999A4P99999999A5P99999999A6P99999999
    N5225A1P-99999999A2P-99999999A3P-99999999A4P-99999999A5P-99999999A6P-99999999
    N5226A1P0A2P0A3P0A4P0A5P0A6P0
    N5227A1P0A2P0A3P0A4P0A5P0A6P0
    N5229P0
    N5230P0
    N5231P0
    N5232P0
    N5233P0
    N5234P0
    N5235P0
    N5236P0
    N5241P0
    N5242P0
    N5243P0
    N5244P0
    N5245P0
    N5246P0
    N5247P0
    N5248P0
    N5270P0
    N5271P0
    N5272P0
    N5273P0
    N5274P0
    N5275P0
    N5276P0
    N5277P0
    N5278P0
    N5279P0
    N5280P0
    N5281P0
    N5282P0
    N5283P0
    N5284P0
    N5285P0
    N5286P0
    N5287P0
    N5288P0
    N5289P0
    N5290P0
    N5291P0
    N5292P0
    N5293P0
    N5294P0
    N5295P0
    N5296P0
    N5297P0
    N5298P0
    N5299P0
    N5420A1P0A2P0A3P0A4P0A5P0A6P0
    N5421A1P0A2P0A3P0A4P0A5P0A6P0
    N5422A1P0A2P0A3P0A4P0A5P0A6P0
    N5423A1P0A2P0A3P0A4P0A5P0A6P0
    N5424A1P0A2P0A3P0A4P0A5P0A6P0
    N5425A1P0A2P0A3P0A4P0A5P0A6P0
    N5426A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
    N5430A1P0A2P0A3P0A4P0A5P0A6P0
    N5431A1P0A2P0A3P0A4P0A5P0A6P0
    N5432A1P0A2P0A3P0A4P0A5P0A6P0
    N5433A1P0A2P0A3P0A4P0A5P0A6P0
    N5461A1P0A2P0A3P0A4P0A5P0A6P0
    N5462A1P0A2P0A3P0A4P0A5P0A6P0
    N5463A1P0A2P0A3P0A4P0A5P0A6P0
    N5464A1P0A2P0A3P0A4P0A5P0A6P0
    N5471A1P0A2P0A3P0A4P0A5P0A6P0
    N5472A1P0A2P0A3P0A4P0A5P0A6P0
    N5473A1P0A2P0A3P0A4P0A5P0A6P0
    N5474A1P0A2P0A3P0A4P0A5P0A6P0
    N5481P0
    N5482P0
    N5483P0
    N5491P0
    N5492P0
    N5493P0
    N5501P0
    N5502P0
    N5503P0
    N5504P0
    N5511P0
    N5512P0
    N5513P0
    N5514P0
    N5521P0
    N5522P0
    N5523P0
    N5524P0
    N5551P0
    N5552P0
    N5553P0
    N5554P0
    N5561P0
    N5562P0
    N5563P0
    N5564P0
    N5571P0
    N5572P0
    N5573P0
    N5574P0
    N5580P00000000
    N5581P0
    N5582P0
    N5583P0
    N5591P0
    N5592P0
    N5593P0
    N5600P00000000
    N5601P00000000
    N5602P01101000
    N5603P00000000
    N5604P00000000
    N5605P00000000
    N5606P00000000
    N5607P00000000
    N5608P00000000
    N5609P00000000
    N5610P0
    N5611P2
    N5612P0
    N5613P0
    N5614P800
    N5615P0
    N5616P0
    N5617P0
    N5618P0
    N5619P0
    N5620P0
    N5621P0
    N5622P0
    N5623P0
    N5624P0
    N5625P0
    N5626P0
    N5627P0
    N5628P0
    N5631P0
    N5632P0
    N5633P0
    N5634P0
    N5635P0
    N5636P0
    N5637P0
    N5640P0
    N5641P1
    N5642P0
    N5643P0
    N5644P0
    N5645P0
    N5646P0
    N5647P0
    N5648P0
    N5660P0
    N5661P0
    N5662P0
    N5663P0
    N5664P0
    N5680P0
    N5681P0
    N5682P0
    N5683P0
    N5691P0
    N5692P0
    N5693P0
    N5694P0
    N5695P0
    N5696P0
    N5697P0
    N5698P0
    N5701P0
    N5702P0
    N5703P0
    N5704P0
    N5705P0
    N5706P0
    N5707P0
    N5708P0
    N5709P0
    N5710P0
    N5721P0
    N5722P0
    N5723P0
    N5724P0
    N5725P0
    N5726P0
    N5751P0
    N5752P0
    N5753P0
    N5754P0
    N5755P0
    N5756P0
    N5757P0
    N5758P0
    N5759P0
    N5760P0
    N5761P0
    N5762P0
    N5763P0
    N5764P0
    N5765P0
    N5766P0
    N5767P0
    N5771P0
    N5772P0
    N5773P0
    N5774P0
    N5775P0
    N5776P0
    N5777P0
    N5778P0
    N5781P0
    N5782P0
    N5783P0
    N5784P0
    N5785P0
    N5786P0
    N5787P0
    N5788P0
    N5791P0
    N5792P0
    N5793P0
    N5794P0
    N5795P0
    N5796P0
    N5797P0
    N5798P0
    N5801P0
    N5802P0
    N5803P0
    N5804P0
    N5810P0
    N5811P0
    N5820P00000000
    N5990P0
    N5991P0
    N5992P0
    N5993P0
    N6000P10000000
    N6001P00100100
    N6002P01000000
    N6003P00000000
    N6004P00000000
    N6005P00000000
    N6006P00000000
    N6010P20
    N6012P0
    N6013P999999
    N6014P5000
    N6015P-224381
    N6016P-143698
    N6017P-425206
    N6018P-384731
    N6025P0
    N6026P0
    N6040P0
    N6041P0
    N6042P0
    N6043P0
    N6044P0
    N6045P0
    N6058P0
    N6109P0
    N6110P0
    N6111P0
    N6112P0
    N6113P0
    N6120P0
    N6200P00000001
    N6201P00000001
    N6202P00000000
    N6210P500
    N6211P1000
    N6212P0
    N6213P0
    N6214P0
    N6215P300
    N6216P300
    N6217P300
    N6218P80
    N6219P0
    N6220P0
    N6221P0
    N6240A1P0A2P3A3P0A4P0A5P0A6P0
    N6261P0
    N6262P0
    N6263P0
    N6264P0
    N6291P0
    N6400P00000000
    N6420A1P0A2P0A3P0A4P0A5P0A6P0
    N6422A1P0A2P0A3P0A4P0A5P0A6P0
    N6423A1P0A2P0A3P0A4P0A5P0A6P0
    N6610P0
    N6611P0
    N6612P0
    N6613P0
    N6614P0
    N6620P0
    N6621P0
    N6622P0
    N6623P0
    N6624P0
    N6630P0
    N6631P0
    N6632P0
    N6633P0
    N6634P0
    N7000P00000000
    N7001P00000000
    N7002P00000000
    N7004P00000000
    N7005P00000000
    N7010P00000000
    N7011P00000000
    N7012P00000000
    N7013P00000000
    N7014P00000000
    N7015P00000000
    N7016P00000000
    N7017P00000000
    N7031P0
    N7032P0
    N7033P0
    N7034P0
    N7041P0
    N7043P0
    N7044P0
    N7045P0
    N7046P0
    N7047P0
    N7048P0
    N7049P0
    N7050P200
    N7051P0
    N7052P0
    N7053P0
    N7054P0
    N7055P0
    N7056P0
    N7057P0
    N7058P0
    N7059P0
    N7060P0
    N7061P0
    N7062P0
    N7063P0
    N7064P0
    N7065P0
    N7066P0
    N7067P0
    N7068P0
    N7069P0
    N7071P0
    N7072P0
    N7073P0
    N7074P0
    N7075P0
    N7076P0
    N7077P0
    N7078P0
    N7079P0
    N7080P6
    N7081P0
    N7082P0
    N7083P0
    N7084P0
    N7085P0
    N7086P0
    N7087P0
    N7088P0
    N7089P0
    N7110A1P0A2P0A3P0A4P0A5P0A6P0
    N7120P0
    N7200P00000000
    N7201P00000000
    N7202P00000000
    N7203P00000000
    N7211P0
    N7212P0
    N7213P0
    N7214P0
    N7300P00000000
    N7311P0
    N7312P0
    N7313P0
    N7321P0
    N7322P0
    N7323P0
    N7331P0
    N7332P0
    N7333P0
    N7400P00001100
    N7401P00000000
    N7440P0
    N7441P0
    N7442P0
    N7500P00000000
    N7501P00000000
    N7511P0
    N7512P0
    N7521P0
    N7522P0
    N7523P0
    N7524P0
    N7525P0
    N7526P0
    N7527P0
    N7528P0
    N7529P0
    N7530P0
    N7531P0
    N7532P0
    N7533P0
    N7534P0
    N7535P0
    N7536P0
    N7537P0
    N7538P0
    N7539P0
    N7540P00000000
    N7541P0
    N7542P0
    N7543A1P0A2P0A3P0A4P0A5P0A6P0
    N7544P0
    N7545P0
    N7559P00000000
    N7560P0
    N7561P0
    N7562P0
    N7563P0
    N7564P0
    N7565P00000000
    N7566P0
    N7567P0
    N7568P0
    N7569P0
    N7570P0
    N7571P0
    N7572P0
    N7573P0
    N7574P0
    N7575P0
    N7576P0
    N7577P0
    N7578P0
    N7579P0
    N7580P0
    N7581P0
    N7582P0
    N7583P0
    N7584P0
    N7585P0
    N7586P0
    N7587P0
    N7588P0
    N7589P0
    N7590P0
    N7591P0
    N7592P0
    N7593P0
    N7594P0
    N7595P0
    N7596P0
    N7597P0
    N7598P0
    N7599P0
    N7600P00000000
    N7601P00000000
    N7602P00000000
    N7603P00000000
    N7604P00000000
    N7605P00000000
    N7606P00000000
    N7607P00000000
    N7608P00000000
    N7609P00000000
    N7610P00000000
    N7611P00000000
    N7612P00000000
    N7613P00000000
    N7614P00000000
    N7615P00000000
    N7616P00000000
    N7617P00000000
    N7618P00000000
    N7619P00000000
    N7620P00000000
    N7621P0
    N7622P0
    N7623P0
    N7624P0
    N7625P0
    N7626P0
    N7627P0
    N7628P0
    N7631P0
    N7632P0
    N7633P0
    N7634P0
    N7635P0
    N7636P0
    N7637P0
    N7638P0
    N7639P0
    N7640P0
    N7641P0
    N7651P0
    N7652P0
    N7653P0
    N7657P0
    N7658P0
    N7665P0
    N7666P0
    N7667P0
    N7668P0
    N7670P0
    N7671P0
    N7672P0
    N7673P0
    N7681P0
    N7682P0
    N7683P0
    N7684P0
    N7685P0
    N7701A1P0A2P0A3P0A4P0A5P0A6P0
    N7702A1P0A2P0A3P0A4P0A5P0A6P0
    N7703A1P0A2P0A3P0A4P0A5P0A6P0
    N7704A1P0A2P0A3P0A4P0A5P0A6P0
    N7721A1P0A2P0A3P0A4P0A5P0A6P0
    N7722A1P0A2P0A3P0A4P0A5P0A6P0
    N7723A1P0A2P0A3P0A4P0A5P0A6P0
    N7724A1P0A2P0A3P0A4P0A5P0A6P0
    N7741A1P0A2P0A3P0A4P0A5P0A6P0
    N7742A1P0A2P0A3P0A4P0A5P0A6P0
    N7743A1P0A2P0A3P0A4P0A5P0A6P0
    N7744A1P0A2P0A3P0A4P0A5P0A6P0
    N7795P0
    N7796A1P0A2P0A3P0A4P0A5P0A6P0
    N7799P0
    N8000P00000000
    N8010P00000000
    N8500P00000000
    N8501P00000000
    N8502P00000000
    N8503P00000000
    N8504P00000000
    N8505P00000000
    N8506P00000000
    N8507P00000000
    N8508P00000000
    N8509P00000000
    N8510P0
    N8511P0
    N8512P0
    N8513P0
    N8514P0
    N8515P0
    N8516P0
    N8517P0
    N8518P0
    N8519P0
    N8520P0
    N8521P0
    N8522P0
    N8523P0
    N8524P0
    N8525P0
    N8526P0
    N8527P0
    N8528P0
    N8529P0
    N8530P0
    N8531P0
    N8532P0
    N8533P0
    N8534P0
    N8535P0
    N8536P0
    N8537P0
    N8538P0
    N8539P0
    N8540P0
    N8541P0
    N8542P0
    N8543P0
    N8544P0
    N8545P0
    N8546P0
    N8547P0
    N8548P0
    N8549P0
    N8550P0
    N8551P0
    N8552P0
    N8553P0
    N8554P0
    N9000P3
    N9001P3
    N9002P8
    N9100P00001001
    N9101P00000000
    N9102P00100110
    N9103P00000100
    N9104P00000100
    N9105P00000100
    N9106P00000000
    N9107P01100011
    N9108P00101000
    N9109P00001000
    N9110P00000000
    N9111P00011001
    N9112P01000000
    N9113P00000000
    N9114P00000000
    N9115P00000000
    N9116P00010000
    N9117P11000101
    N9118P00010000
    N9119P00000000
    N9120P00000001
    N9121P00000000
    N9122P00000010
    N9123P00000000
    N9124P00000000
    N9125P10000000
    N9126P00001000
    N9127P00000000
    N9128P00000000
    N9129P00000000
    N9130P10000011
    N9131P00000000
    N9132P00000000
    N9133P00000001
    N9134P00000000
    N9135P00000000
    N9136P00000000
    N9137P00001000
    N9138P00000000
    N9139P00000000
    N9140P00000000
    N9141P00000000
    N9142P00000000
    N9143P00000000
    N9144P00001000
    N9145P00000000
    N9146P00000000
    N9147P00000000
    Mar 2014
    FINLAND
    26
    8
    Seems I messed with the error led url. It's: https://www.*******.com/forums/fanuc...tml#post823937
    Also, see the attached pics for the machine configuration. Inerested also if the option parameters match with the machine parameters. There is an attached robot interface, so there can be differences because of that, too.
    Attached Thumbnails Attached Thumbnails trap15.jpg   14.jpg   24.jpg   34.jpg   44.jpg
    Jan 2014
    Washington
    4,582
    838
    2486
    TRAP15 alarm means a trouble with the system software.
    There are several differences in the option/configuration parameters in the file you attached when compared to the list shown in the 14.jpg picture you posted. Incorrect option/configuration parameters could be the cause of the system software not operating properly and resulting the TRAP15 alarm. You need to get the correct option/configuration parameters loaded.
  4. Likes antonmies liked this post
    Mar 2014
    FINLAND
    26
    8
    Thank you Vancbiker for the answer! Seems there might be a possibility that nothing is trashed then?
    As far as I know, there has been the added robot interface and if I've understood correctly, tool control and setter has been added after the initial purchase and they might explain the different option parameters, at least for some part?
    Could it be that the remote buffer is set to be used with the robot? If that would be the case, I think that the robot interface should be removed as I don't have any use for it.
    Do you know anyone who could help with the option parameters?
    Jan 2014
    Washington
    4,582
    838
    2486
    I have never worked on a 15 with the remote buffer board. I'll try to look that up and see what it may possibly be used for.
    Usually if a Fanuc tech changes option/configuration parameters they will mark the hard copy sheet with the updated values. I would expect that to be the case if the remote buffer board were added after the machine was sold/installed.
    Where did the parameter file list you posted come from? Is it an old backup from this machine at some point when it was operational? I have run into cases where someone has reloaded a parameter file from a different machine which results in all kinds of strange problems. Sometimes people think that a parameter file from a different machine is OK as long as the control model is the same. This is not a true assumption.
    The label in the picture you posted is from a digital output module for the I/O rack. It will be one of the yellow modules in the picture of I/O rack you posted.
  7. Likes antonmies liked this post
  8. #6
    Mar 2014
    FINLAND
    26
    8
    Thank you!
    The remote buffer (and DNC2) function are both listed in the 34.jpg listed above.
    The parameter list is from the machine itself. I bought the machine from a school and I don't think that they would of had a need to load params from another machine as there is also history of some maintenance made by the Takisawa importer during the years. I contacted them earlier about machine properties, but didn't really receive any answers even I dind't expect to have them for free.
    Have I understood correctly that the Op values in the sheet are hex values and need to be converted binary and OP1->9100, OP2->9102 etc.? If I got it right, seems some are completely different... But I also find it unwise to directly replacing them as the control could go brick if the differences are correct?
    By the way. I have two different ladder diagrams. There is the original one and there is a note label that says "Original ladder, not useful" and the latter one has marks that tell me that it was installed by the importer. I believe this was done after adding the digital I/O module.
    I sent some questions related to this to the importer, too, but am not really expecting any answer from them...
  9. #7
    May 2013
    CANADA
    Ontario
    39
    11
    My 2 cents: I agree that it is likely a wrong option configuration. You also should figure out which ladder is actually running; if you have an dynamic ladder display (visible in the pmc display), you could compare that with the two printed versions.
    I have the option list for that control; the hard part is selecting which option needs specific hardware and also may be dependent on software version (displayed on SYSTEM CONFIG screen).
    So, lets start with the software version that you have.
  10. Likes antonmies liked this post
  11. #8
    Mar 2014
    FINLAND
    26
    8
    Please find the modules and software screens from system config.
    Also, I initially described the problem incorrectly. When I transfer file through channel 10 while at edit mode, then the trap error appears, but if the machine is in tape mode, the control hangs completely. Not sure if this has any relevance but though to share it anyway.
  12. #9
    May 2013
    CANADA
    Ontario
    39
    11
    our software version is A31AD (15A-TF level up).
    These are the options present from your parameter list:
    bit description
    N9100P00001001 0 Simult. cntrld. axis exp.
    3 Skip function
    N9102P00100110 1 Inch/metric conversion
    2 Canned cycle
    5 Cutter comp. C
    N9103P00000100 2 Chamfer/corner rounding
    N9104P00000100 2 Multiple repetitive cycle
    N9105P00000100 2 Manual handle feed 1st
    N9107P01100011 0 Spindle speed output, analog
    1 Constant surface speed
    5 Tool life management (1st parm)
    6 2nd Aux. function
    N9108P00101000 3 Tool length measurement
    5 Rdr/punch interface A (1st parm)
    N9109P00001000 3 Tool offset memory B
    N9111P00011001 0 Custom macro (1st parm)
    3 Expanded part program editing
    4 Custom macro, 200 variables
    N9112P01000000 6 Custom macro (2nd parm)
    N9116P00010000 4 Tool life management, 512 pairs
    N9117P11000101 0 CNC window B
    2 Tape reader rewind - RS232C
    6 Cylindrical interpolation
    7 Polar cord. interpolation
    N9118P00010000 4 Rdr/punch interface B (3rd parm) and Rdr/punch
    interface A (3rd parm)
    N9120P00000001 0 Part program 40 M
    N9122P00000010 1 Tool life management (2nd parm)
    N9125P10000000 7 Tool offset meas. B
    N9126P00001000 3 Work coordinate system preset
    N9130P10000011 0 Auto process selection
    1 Animated drawing
    7 C-axis FAPT
    N9133P00000001 0 Remote buffer interface (2nd parm)
    N9137P00001000 3 DNC1 Interface
    N9144P00001000 3 DNC2 interface function
    Maybe there is a problem in the Remote Buffer board. Is the problem new? Was anything changed since the last time it worked?
  13. Likes antonmies liked this post
  14. #10
    Mar 2014
    FINLAND
    26
    8
    Thank you for your effort!
    So it seems to you that the config is correct for the installed modules?
    I have nothing but vague info from the machines history. Nothing from the party that used/administered the machine and the condition is as is I originally bought it, despite the replaced UART chips.
    The next step would then be to test the Remote Buffer card, I guess the "easiest" method would be to locate someone with a machine that has the same unit installed and send mine to be tried in his/her working environment?
    Are there any other parameters that might affect the behavior? Also, I'm wondering why the G05.1 isn't present in the system?
  15. #11
    May 2013
    CANADA
    Ontario
    39
    11
    G05.1 is an option not enabled in your control:
    High precision contour (requires J986).G05.1; HPCC w/o RISC. Cannot have J704 (HPC w/RISC); use 9035 or 904x servo software. REQUIRES SUBCPU.
    J986 = 9116 bit 2, (also not turned on) Multi buffer 15 blocks;;Special w/o sub cpu but all features of AA01 + rotary head features J728 & J729.
    Now you see how hard it is to do the correct combination of options.
    I can't tell the part # of your Remote Buffer board (A16B-2200-017X); I don't seem to have one.
    Look at how your comm ports are set up on the control.
  16. Likes antonmies liked this post
  17. #12
    Mar 2014
    FINLAND
    26
    8
    Thank you memoryman! You've been most helpful!
    The RB card no is A16B-2200-0170/11A.
    I made a test and gave the board some gentle heat. The result is that trap error etc. isn't happening anymore and neither is any reaction to transmission. Seems like some soldering issue is a probable cause of the issue. Might as well be some failing/failed component, I guess.
    It seems that the board communicates with the CNC controller, though, as if I remove the card, there will be an error that 'remote buffer not available'.
    Luckily the "punch panel" / RS232 through CD4A transmission works and I can drip feed using that so I can get the machine operational and think of the remote buffer later.
