Hi,
First of all, sorry for this elementary guestion. I just headed to dead end when trying bore hole with G03 and using G42 tool radius compensation. This program works if I remove the G42 (but 15mm too big hole). When it runs the block for G42 fanuc will give error "041 interference in CRC". I can't seem to figure out what is going wrong. So this program should bore 4mm deep 28mm diameter hole with 15mm end mill. Work offset is at the center of hole. Here's the code:
Code:
O0001;
M06 T01;
G90 G21 G17 G94 G80 G54;
G00 X0.0 Y0.0 S1500 M3;
G43 Z50.0 H1;
Z5.0;
G42 X-14.0 Y0.0 H1;
G01 Z0.1 F200;
G03 X14.0 Y0.0 Z-2.0 R14.0;
G03 X-14.0 Y0.0 Z-4.0 R14.0;
G03 X14.0 Y0.0 R14.0;
G03 X-14.0 Y0.0 R14.0;
G01 X0.0 Z1.0;
G00 Z100.0;
G40;
M30;
