manyponies
- Jan 22, 2020
Sometimes when I am copying a program from the memory card to the control memory the Program number changes. The control adds a "0" inbetween the the Program number and the program name. I have tried copying the program to the control using "file number" and "file name" methods with the same results
I enter the program number and push "OSET" on the control. The program copies but the shows the file number in the memory directory but without the showing the comment that follows, I bring the prodram to the screen with the "OSEARCH" and it loads but has an extra "0" between the file number and comment
Example
O0001(PROGRAM 1) This is what I should see
O00010(PROGRAM 1) This is what I do see
I can delete the program using O0001 DELETE but if I try tho run the program I get an alarm that says " TOO MANY DIGITS"
This seems random. Sometimes the programs copy correctly and sometimes they add this extra digit
Any ideas ?
Example
Any ideas ?
