Hi
I had crash in X on a long part being held in my 5C threaded spindle nose, this has cracked the spindle nose to the point where the runout is excessive. The Lathe is an older Takahashi TNC-L-T0 running Fanuc - 21T. I took the spindle apart and from measurements it appears to be A2-3 spindle however with metric bolts (3xM10). I am wondering who might be able to supply a 5c threaded spindle nose in A2-3 ; I've looked around but no one seems to list this type of spindle nose .
I've taken a crack at reverse engineering one but I'm not clear on the 5c tolerances as I use a lot of threaded collet closer tooling and my home-made version I'm not sure on where to bottom out the closer.
Any tips on suppliers in North America or should I look at making mine better ?
-P
-P
