Hi. Maybe somebody knows how to run program from pc, mastercam to cnc milling machine, if there is possibility? I remember, when I worked few years ago, we can run machining directly from pc with fanuc 21 iM controller. We hit auto button, drip feed button in right upper corner, then cycle start, and lsk shows on. With mastercam we send nc code, and machine starts runing when you adjust feed/rapid handles. Or maybe there is another way how to expand memory? Cause we can run only short nc codes. Thanks. Machine leadwell V-25. I know it's old, but some peoples wanna to run it, for some jobs.
