Fanuc 21i-T
Likes Likes:  0
Results 1 to 14 of 14
Thread: Fanuc 21i-T
    Mar 2016
    PORTUGAL
    9
    6
    Default Fanuc 21i-T
    Hi,
    I work with a lathe with Fanuc 21i-T.
    G54 is modal, and in the workshift page there are no options for G55, G56, etc.
    I tried all options on the menu, and on the web also.
    Maybe parameter 9936 (?) has to be set...anyone can help please?
    Regards
    Mar 2003
    Upstate New York USA
    308
    52
    It is most likely a Fanuc option the builder did not pick up and offered as an option, I dont have the option bits in front of me at this time to confirm your parameter. You should still have a WSHFT softkey whcih will allow you to set a workshift
    Jan 2019
    Missouri
    403
    107
    102
    I feel like we have plowed this field before?
    I dont think you can have workshift and work offsets at the same time.
    Feb 2006
    South Carolina
    394
    65
    My 21t is the same. I use g10 for different work offsets.
    Dec 2018
    210
    526
    57
    Workshift is all on its own page on the 21iT I work with.
    When I hit the Offset/Settings button, the option for Work is there as a soft key. Hit the Work soft key and I get the EXT and G54-G59 work offsets.
    Jan 2019
    Missouri
    403
    107
    102
    Quote Originally Posted by Fancuku View Post
    Are you saying you have both the Workshift page and a Work Offset page (G54s)?
    Dec 2018
    210
    526
    57
    Quote Originally Posted by GENERALDISARRAY View Post
    Yes, I have both. To get to the workshift page I have to hit Offset/settings button and then hit the "+" soft button. Only then the Workshift page will be available.
    If OP sees G54 as modal when the machine is first turned on then it means that his machine has G54-G59 work offsets. He just hasn't figured out how to get to the correct page yet.
    Jul 2013
    Indiana
    3,420
    5023
    1756
    I'm finding it hard to swallow that a Fanuc i series controlled machine doesn't have G54-G59 fixture offsets.
    Brent
    Feb 2007
    Aberdeen, UK
    4,561
    1660
    2127
    That's not necessarily the case. I know from experience that on some Fanucs G54 will be on by default and modal even if work offsets are not activated. Trying G55 etc. in MDI is the definite way to know. It will either work or issue a PS alarm.
    I have an older O-TC that I activated work offsets on, and it always had G54 on by default even before the option was activated. On that control work shift and work offsets are toggled on the same softkey, i.e. there is no indication of how to access the work offset screen at all, you just have to know that if you press the work shift softkey when already on the work shift screen it toggles to work offsets.
    Mar 2003
    308
    52
    yes it possible to have both the workshift and work coordinate systems (G54-G59) on at the same time, the workshift is standard from Fanuc the the work coordinates is an option which the builder must order in their control package
  11. #11
    Mar 2016
    PORTUGAL
    9
    6
    Quote Originally Posted by Tom View Post
    Yes, but just a generic "G". Not G54, or 55...
  12. #12
    Jan 2019
    Missouri
    403
    107
    102
    Quote Originally Posted by leoneljbsantos View Post
    There are good answers posted. Did you MDI "G55" or others?
    If it doesnt change the modal work offset to what you entered, then you dont have the option.
    You cannot enable the option yourself.
  13. #13
    Oct 2017
    6
    Hello
    Im trying to get my Romi M17 lathe running . It comes on , but I am not sure how to enter a manual program , just simple stuff for now .
    ben
  14. #14
    Jul 2013
    Indiana
    3,420
    5023
    1756
    Quote Originally Posted by sonofachip View Post
    Hello
    ben
    What in the world made you ask this question in this thread? I believe if you type in O5150 not zero but the capital letter O and a 4 digit program number plus the "EOB" (end of block) then "insert" will create program 5150 in the program directory. Then just start writing as normal.
    I'm assuming you have a Fanuc 21i-T on this thing.
    Brent
