Fanuc 21i-t pmc programming needed
Likes Likes:  0
Results 1 to 2 of 2
    Apr 2013
    Zanesville Ohio, USA
    16
    Default Fanuc 21i-t pmc programming needed
    I have a lathe with a 21i-t.
    I need several things added/changed in the pmc program.
    I am more than happy to pay something reasonable for someone to make some changes.
    I can send you the program.
    Here’s what I need;
    Be able to pause program, jog axis, then restart program where it was paused at.
    F1 key to switch spindle between run and jog. (Spindle start button just jogs it now)
    F2 run spindle at 100 rpm
    F3 select external jog wheel
    Setup info/programming for external mpg with axis selector and step selection. This is for a hand held mpg.
    Jun 2018
    Wisconsin
    107
    7
    53
    Quote Originally Posted by Bakeng View Post
    "Reasonable" for this request alone would be about 6 figures. "Lathe with 21i" does not even come close to describing how the ladder currently functions and what functionality the MTB has programmed that would be roadblocks to your desired functionality. The reason that high end machine tool builders crow about such features is because they're damn hard to do safely covering all known and many unknown forms of carelessness.
    Hopefully you can find someone who's willing and capable of helping you, the second rules me out.
