JLaugh
- Jan 21, 2015
- East Tennessee
Fanuc 21i-a t controller
Absolute digital encoders
Cincom BL12 type V machine
2 dual axis controllers (z1/x1 and y1/x2)
2 single servo amplifiers for spindles
The software for the machine was reloaded a few years ago.
Supposedly, everything was working correctly except for the Z zero postion.
This issue has been programmed around for a few years.
The guy over this machine has stated they had the machine physically apart down to the z axis mechanics.
I wonder if they dropped the ballscrew nut??? down one side when they removed the top plate and pulled it up the other side during reassembly without realizing that it would put the encoder off one revolution. Then never did a 1815 APZ procedure.
The citizen guy claims that the 1850 gridshift value is always metric and is viewed as 0.000 mm. My investigations seem to support this when making small adjustments to the 1850 z1 value. When a large adjustment is made unexpected changes happen.
The factory 1850 value was set at -4076 in may of 2001. The 1850 value was set at 1000 on 12-13-2013. Currently the -4076 value nor the 1000 value are correct according to alignment procedures.
I investigated the possibility of the value being detect units. My thinking was that the multiplier may be close enough at small increments to make detect units and 0.000mm units yield close results. When doing the math on the detect units it still falls victim to the unexpected hard measurement values.
I have resorted to making small increment changes in the 1850 paramter to find a good place to for usability. I have pinned it down to a value of -650 or -649.
This is a fixed headstock cincom with a stopper for barstock feed control. In the Z1 axis - takes you closer to the main spindle while positive takes you further away. (backwards from most cincom machines).
At an 1850 value of -649 we are .085" from the procedural value of hard measurement.
At an 1850 value of -650 we are more than -.1181" from the procedural hard measurement.
Why is there such a large value shift when cincom claims that the value is only .001mm different?
Why would the abnormality happen at such a specific number and be repeatable?
I am afraid to do the 1815 APZ procedure because currently we have a usable if somewhat downgraded machine. At the same time though maybe that's all thats wrong with it?
My thought is that maybe and absolute reference mark is at the -649/-650 postion mark on the encoder and that throws it off some how.
I have tried homing the machine within one revolution of the manual zero return mark and it doesn't seem to make any difference. I have been through the entire parameter manual and can't link any bad values to the issue. Maybe it is something simple I have no knowledge of that someone with more expierience can answer easily. I believe I have done my due diligence with researching parameter manuals, looking at other 1850 threads on this site and any others google will pull up. I apologize if a similar issue has already been answered and I could figure it out from those answers.
