Hello Everybody,
For my research, I need to run the G Code on corner contour mode is on. When I first inserted the activation code G5.1 Q1 it worked. however, I could not make it happen again. I might have done some little changes but I do not remember what I did.
I would like to give some experimental results to explain the problem more.
When I do not use G5.1 command, the feedrate does not decreased on the corners. ( it may seem like it decreases, but it does not actually. I can explain why if needed )
When I inserted the G5.1at first, the velocity profile was (Correct, what I wanted to see):
When I made tried it again the same code (I might have done little changes as I said but, G5.1 was still there) I was getting the result all the time which is incorrect. And the result was being shown regardless what the tolerance value is (R1...R10)
If you can mention what I could have done wrong I would be so glad. Whatever I tried I could not get the result like 2. image.
Thank you in advance.
