FANUC 31i-A: Using Taster probe in program but machine throws spindle alarm
rbmgf7
Oct 18, 2017
So I have a program where I can select a macro to call the Taster 3D probe in an HMC and feed into the part where I need to index. However, when I jump into my first G1, the machine alarms for "G1 command error, rotate spindle".
Yeah, I get it. Machine knows the spindle isn't on when it's feeding.
So how do I get around this? I DO NOT want the spindle on obviously.
Setup goes
G0 G90 G94 G98 G54
Tried M5 with nothing. Googled and got some weird suggestions.
Thanks.
Setup goes
G0 G90 G94 G98 G54
Thanks.
Sometimes the MTB has a keeprelay to allow feed w/o M3/M4. Sometimes not. Sometimes an Mcode. Sometimes not. Have to check with them.
Why do you need G1 with a 3D Taster?
I'd feel more comfortable feeding the probe into the place I can touch off on. I guess can G0 close then handle it in but since it's the same place for a fixtured part, I can get it in position so I can just look at the dial for the difference.
