camaro_dan67
Cast Iron
- Dec 4, 2009
- N.E. Pa.
Is there a way to get either the absolute or relative displays to show the correct z position for the current tool I am using? It only shows a large negative number in z while the tool is cutting the part. The x and y positions are correct. I use G92 for my work offset in x and y and G43 in the program to call tool offsets from the tool table.
Thanks, Dan.
Thanks, Dan.
