camaro_dan67
Cast Iron
- Dec 4, 2009
- N.E. Pa.
Here's where it all started. I started my mill up this morning homed it and ran the simple drilling program I was running for the last week. Everything seemed fine until I switched from auto to manual and tried to move the z axis with the mpg. I was handwheeling in the Z- direction and all of the sudden it jumped like it was in a higher increment. The control displayed multiple errors one was the watchdog alarm. One of the others was a vrdy off. I was able to reset it by hitting the estop releasing it then pushing the ready button again. After getting multiple errors while trying to hand jog different axis around I put the machine back in auto and cautiously ran the same program with no parts, it had no trouble. I then had to shut the machine off and come back to it later. When I tried to restart it there was no screen and no motion. I called Fanuc and the guy walked me through a few things to check. He claims its either the power supply or the motherboard. He also had me try to start it up holding down the reset and delete buttons. I tried that and nothing came up. I did check the voltages on the power supply and they were all within .5 of a volt to what they were supposed to be. Does anyone have any suggestions on some other things to try. I don't want to spend the crazy amount thats wanted for the motherboard on this machine only to find out its something else.
Thanks everyone, Dan
