adamm
Cast Iron
- Sep 19, 2008
- Kingston, ON
I have a Matsuura mill with a Fanuc 6MB controller. When running with a tool offset set by G43, the position display does not show the Z value with the offset applied. So if I have my G54 offset set such that the top of the part is Z=0, and the tool has an offset of 2.0, the display shows Z=2.0 when the tool is at the top of the part. I want it to display with the offset applied, so that it shows Z=0 at the top of the part, rather than showing the offset.
Searching around, it appears that this is controlled by a parameter in many Fanuc controls, but I haven't found any specific reference to the 6MB. I've been through my Fanuc Manual's list of parameters, and there is only one that looks like it may control this behaviour. Before I muck something up, does anyone know if this is the correct parameter?
Parameter 7, bit 1, called PPD. The description is:
1: Position display is preset by G92
0: Position display is not preset by G92
The current setting is 0
I'm generally not using G92 when running the machine, but it is the only parameter I found that deals with "Position Display".
Thank you,
Adam
Thank you,
Adam
