subway_savage
- Aug 8, 2016
Hi,
I have a flat bed lathe with a Fanuc Powermate controller, i am getting x axis alarm 414 (and sometimes 411 along with it) repeating on the same program on the same position, If i restart the machine it goes away and alarms back on the same exact spot (taking a Z finish pass). what could cause this to alarm out on the same spot ? the roughing passes worked fine.(this program was run before without issues)
This alarm appeared before a few times on the same axis when the machine is first powered up but never during a program. The servo amps do not have a number display for the code
I was thinking of swapping the servo amps to see if the alarm stays or moves to the other axis. And maybe disconnect the motors from the ball screw and run the program to eliminate any mechanical issues.
Thank you.
Thank you.
