alienturtle
- Sep 7, 2018
Hey guys. Iv been trying to learn as i go with my makino rmc55. It has fanuc o mate mf controls and a model L pmc
So the previous owner of this machine added a 24v air solenoid and ran a hose for an air mist setup. This solenoid cycled with the coolant on off button on the console. When i checked power to my coolant pump wires it was dead. Inside the cabinet they un hooked the wire feeding the contactor for the coolant pump and wired in this air solenoid.
So technically i can fix my coolant pump issue no problem. After more digging i noticed an air mist button on the console as well as a place holder for a relay marked mist. I busted out my manual and found the coil side is triggered with the 190 wire which translated to y48. 6 output. I was able to turn param 60 bit 2 on to show the ladder. Did a search for y48. 6 and it showed up in a few places. I also noticed an f296.2 would cycle when i pushed the air mist botton. What i dont understand is how the button f296.2 is getting to trigger y48. 6? Does y48. 6 need to be on the right side of the ladder with a circle under it to work? The mist shows up as an option in my manuals and wire diagrams. Thanks guys.
