Rick Finsta
Stainless
- Sep 27, 2017
So of course my first day back in business for myself my CRT goes wonky on my 2005 Sharp SV-2412 with 0i-Mate MB. It has the A61L-0001-0093 made by Toshiba. I had the control panel opened up to trace a signal to see what would be involved in adding CTS to the machine, and when I installed the screws after closing the panel back up, the display began very quickly rolling as if the sync is off or something. I can use any of the soft keys and see the screen changing, so it looks like just a video error?
The only other thing I had done yesterday was Change parameter P7061 from "12" to "2" as per Sharp's recommendation for running the G05.1/G08 commands.
I was going to pull the trigger on an LCD replacement but wanted to know if I should start tracing the issue back further? I tried power cycling and disconnecting/reconnecting a few plugs, but that's about all I wanted to do without knowing if I should go further or just replace the screen.
