gregormarwick
- Feb 7, 2007
- Aberdeen, UK
When you execute a macro with G65 or by custom G code the program run display traverses through the macro code as it would with any other program.
Is there a parameter that can be set so that it doesn't do this?
I have a number of proven macros, especially those that are assigned to custom G codes, where it would be better for the operator if the code that calls the macro remains in the run display until the macro is completed, rather than jumping into the macro code.
Especially in MDI I would prefer that the run display did not jump into the macro code.
Edit: control in question is an 18i-TB
