Basically having issues controlling the threadmilling cycle which should be fairly straightforward. I’m getting two errors depending on where enter the threadmills radius. First error is PS0020: Over Tolerance of Radius. Using a 9.9MM diameter 1/4 NPT threadmill. The second error is PS0041 Interference in G41/G42 when entering the 4.45mm radius in the geometry page. The code is as follows
G97 S2000 M13;
X50.878 Y0.0 Z24.486;
M484
X0.0 Z20.;
G10.9 X0.0 (RADIUS) ( have entered radiuses from 5mm down to 4mm in here in X value);
Z-10.3283;
G01 G41 X0.941 Y-5.5197 F20.;
G03 X4.5723 Y4.5723 Z-10.0296 I-6.4634 J.0067 F52;
G10.9 (Dia) (this line as at the end of the process
Thanks in advance.
G97 S2000 M13;
M484
X0.0 Z20.;
Z-10.3283;
Thanks in advance.
