Fanuc G76 2 line Threading Cycle example.
Heinz R. Putz
Stainless
Mar 16, 2006
Columbus, Ohio
I recently had a call for advice from a shop that bought a 6T Mori and needed help.
I sent him this example from my website, older machines are still around and sold a lot, maybe it can help somebody else.
The 2 line version came in with the Fanuc 0T, the 6T had the 1 line version, but is quite similar.
Here is an example of the G76 as it should be, its part of my DVD called Cycles.
The only difference is that this is the 2 line version, you have 1 line.
Its for the 0T control and did not need the G50 dimensions.
You can not use G96, use G97.
Example: G76 Threading Cycle in 2 line format for OT and later controls.
2" diameter, 20 Threads per Inch, Mild Steel.
O2006*
N1 G50 S1500*
N2 T0101*
N3 G97 S700 M3*(Speed for threading, always in RPM)
N4 G0 X2.2 Z.2 M8*(Rapid to above part, .2" from face)
N5 G76 P021060 Q20 R5*(The first 2 digits in P represent the amount of finish
passes, the next 2 are the pullout distance at the end of the threading motion,
expressed in tenths of revolutions, the 60 is the angle of the tool)
N6 G76 X1.94 Z-1.0 P300(total thread depth) Q150(depth of first cut) F.05*
R if needed is the amount of taper over total distance in thread motion.
The P value is figured by taking the F-value times the constant of .6, once
figured you also have the X value.
N7 G0 X6.0 Z6.0 M9*
N8 M30*
If any of you need help, advice is free.
Heinz at doccnc.com
