Fanuc M 0 controller - Issues homing and Y overtravel
Results 1 to 18 of 18
    Dec 2017
    NORWAY
    80
    26
    20
    Default Fanuc M 0 controller - Issues homing and Y overtravel
    Hi there.
    We have some issues with our CNC machine with Fanuc M O controller.
    It started with a stuck switch below the table on the machine. We got the switch unstuck and testet
    the switch for function. But then the table was not near end travel on Y axis. Now the machine remembers this position and we cannot move the Y axis to home position before the end of travel alarm comes on.
    I reckon I must in the paramteres to change some input to get the table back to its max travel?
    Jun 2018
    Idaho
    79
    20
    Try this. Power down machine. Power back on holding down the P and CAN keys at the same time. See if you can home the machine now.
  3. Likes Ox liked this post
    Dec 2017
    NORWAY
    80
    26
    20
    Quote Originally Posted by VTM View Post
    Sure. Will try that tonight
    Dec 2017
    NORWAY
    80
    26
    20
    Did not work... Y travel max is still "stored" about half of the travel available on the machine.. I thinking there is some parameters that needs changed?
    Jun 2018
    Idaho
    79
    20
    Well, have a read through this.
    Fanuc 0M: Re-setting zero return.
    Maybe it will help you out. Was the machine running fine before and the stuck switch caused this? If so p+cancel on boot up should have worked.
  7. Likes Ox liked this post
  8. #6
    Dec 2017
    NORWAY
    80
    26
    20
    Yep machine was running fine. But when we testet the switch the Y axis was not at end of travel, and seems that the position we had the table in when we testet the switched is stored. Now the machine gives Y overtravel at the exact same spot and we cannot move the table beyond that position. That is why my theory is
    that something has been stored in a parameter somewhere that makes the machine believe that it is at end. Like a soft stop.
  9. #7
    Jan 2014
    Washington
    3,885
    723
    2025
    The Y soft limit parameters are 701 for the positive direction and 705 for the negative direction. Assuming you are getting alarms 520 or 521 when you try to move Y, you can set 99999999 to 701 and -99999999 to 705 and that should essentially cancel the soft limits and allow you to reference home the axis. Once you successfully home the axis, return the parameters to their factory settings.
  10. Likes Ox, Kjeksen liked this post
  11. #8
    Nov 2012
    Australia
    91
    7
    sounds like the reference point return needs to be reset.
    zero the axis bit then perform a reference point return and the switch will automaticaly set it.
  12. #9
    Dec 2017
    NORWAY
    80
    26
    20
    I have no idea what the factory settings is because the the number stored in parameter 705 is the position we tested the switch in, not the factory setting. 705 is -46000000 wich is the travel of the table in Y axis according to the MTB data I have.
  13. #10
    Aug 2002
    West Unity, Ohio
    24,448
    4580
    7368
    Did you keep the CAN and P buttons held down the entire duration of boot-up time?
    Think Snow Eh!
    Ox
  14. #11
    Jun 2006
    Oregon
    381
    53
    I do not see that you mentioned the machine type. Does it have manual control wheels as well as the servos by any chance? Had a Taiwanese bed mill with this problem because someone had played with the X-axis manual wheel while the power was off.
  15. #12
    Dec 2017
    NORWAY
    80
    26
    20
    Yes. Aslo tried it several times.
    Think Snow Eh!
    Ox
  16. #13
    Dec 2017
    NORWAY
    80
    26
    20
    Quote Originally Posted by imported_brian_m View Post
    Ah sorry bout that. It is a mill. No manual control wheels.
  17. #14
    Jan 2014
    Washington
    3,885
    723
    2025
    Quote Originally Posted by Kjeksen View Post
    The above does not make sense.
    Did you set 701 to 99999999 and try to move the Y?
  18. #15
    Dec 2017
    NORWAY
    80
    26
    20
    Yep. That did work. But the parameter had 3000 stored in it. Wich is not the correct number.
    Did not get to see what the right number in this parameter was before it got stored as the wrong one.
  19. #16
    Jan 2014
    Washington
    3,885
    723
    2025
    So, were you able to zero return the axis? Once that is done then you should be able to set 3000 back to 701 and all should work fine. 3000 sets 3mm from the zero return point to the positive soft travel limit.
  20. Likes Ox liked this post
  21. #17
    Dec 2017
    NORWAY
    80
    26
    20
    Yep. Got to home Y axis!
    Works great now. Set the 701 parameter back to 3000 and works like a charm.
    Thanks guys!
  22. Likes Ox liked this post
  23. #18
    Oct 2005
    Wilmington DE USA
    1,934
    299
    401
    Just came in this morning and I had a 520 alarm on a NTC vmc w/Omb
    As the limit switch appeared a little sticky I figured that was the problem
    Machine hasn't run in a couple weeks and the temps are starting to get cold
    I tried the usual "p can" with no avail
    Ready to start taking things apart I figured a search on here to confirm any thoughts was appropriate and I found the above instructions re rewriting par 701 705 and homeing
    After finally remembering how to get into the parameters and following above instructions, I'm back up and running
    Many thanks to those above, my Monday won't be so bad after all
    Mike
  24. Likes Vancbiker, Ox liked this post
