ROY_WERNER
- Feb 14, 2020
Dear all,
Have a Enchu DTL CNC mill from 1991. The machine is almost unused (school machine).
So... after the holidays -> backup battery flat.
Need to load parameters. I found the punch tape from the factory with parameters and got myself a tape reader. So at the moment I have this tape saved as ASCII on a PC w/RS232
For all 500(P-Code) - and 900-series parameters I only have a paper copy from the maker Enshu factory and need to enter manually. When parameter 905 is set accordingly to hardcopy -> Alarm 000 -> Reboot -> Alarm 911 (Parity high error). If I leave parameter 905 = 0000 0000 I can load all parameters from PC. When rebooting the machine I’m asked to run with or without PMC…. (if I set parameter 905=0000 1000 according to paper copy -> Alarm 911 again)
I’ll try again with following plan:
Pls comment and correct me!
Thanks!
- Install new Backup battery and measure Voltage out from battery housing (Done Voltage - OK)
- Clear Mem
- Enter 900-series of parameter (with power down/up on Alarm 000)
- After entering parameter 901 I’m asked to press "DEL" or "CAN" to continue… I choose “DEL”
- Enter 500-series of P-Code variables
- Enter, manually, the Parameter List parameters (On my machine parameter goes to 999 then jumps to 8000 how to enter Prm between those?)
- Then run procedure to generate ATC-macro
Thanks!
