Ruben
Do you have DNC set up & running to this machine? Out putting Parameters is easy, and good practice. Assuming you are all ready date talking with the machine. Just be in Edit mode. Parameter Key, so that your on the parameter page, and hit Start.
You should see the blinking cursor or LSK flashing. Save or open that in a plain text editor like Note or Word Pad. Then visually compare them to what you have in the control.
Be very, very careful that you have them all. Particularly the 900 group ones.
If you haven’t got DNC. Cadam has a free trial version that’s good for this. Its easier if you set your DNC up first, cause its much easier to re-load them, if you have them on file.
Like wise you can spit out all your programs. Edit Mode, Program Key, Start.
I’m guessing Files 001 – 015 are just programs. Unusual location if they are machine macro’s. Try searching them. Be in Edit mode, Press “O”, Curser down.. That should scroll you through all stored programs. I don’t think you can protect low program numbers like that., so you should see them.
Regards Phil.
(Adding on Edit). P.S Bro. turn the Caps lock off. Its kinda considered shouting, and can get you slapped about here.
