Fanuc O-TC and G54
Results 1 to 19 of 19
    Feb 2007
    Aberdeen, UK
    3,306
    1173
    1235
    Default Fanuc O-TC and G54
    The O-TC does not support additional work offsets (not even as an option AFAIK), instead relies on work shift.
    G54-G58 do not exist and alarm out when you try and enter them.
    However, it is somehow aware of G54 as it's clearly set as a default at startup, it's right there in the list of active modals.
    Is there any way to prevent this control from alarming out when it encounters a G54? It's the only real hurdle in being able to use a single unified post for my O-TC and our Oi-TC.
    Sep 2010
    Victoria Australia
    3,557
    1396
    Quote Originally Posted by gregormarwick View Post
    Hello gregor,
    I suspect that the alarm being raised is p/s010. That being so there is no parameter solution I'm aware of, but there is a fudge you could use. Register the number 54 in whatever parameter that is available between 6050 and 6059 to create a Custom G Code, G54. Lets say 54 is registered in parameter 6050, create a program under the number O9010 that contains nothing other than M99 to return control to the calling program. When G54 is encountered in your program, program O9010 should be called and immediately return control to the Block following where the G54 in the calling program was encountered.
    Regards,
    Bill
    Feb 2007
    Aberdeen, UK
    3,306
    1173
    1235
    Quote Originally Posted by angelw View Post
    Hello gregor,
    Regards,
    Bill
    Very clever Bill!
    When the machine is finished it's current job I'll give that a go and let you know how I get on.
    Alternatively, that solution might be somewhat confusing to the operator, so I might have to live with two posts. We'll see!
    Cheers.
    Sep 2010
    Victoria Australia
    3,557
    1396
    Very clever Bill!
    Cheers.
    Hello gregormarwick,
    It should be no more confusing than the program encountering a G54 and not raising an alarm. If the O9000 Series Programs are protected and hidden via parameter, as they should be, the operator will not be aware of the Macro Program being called by G54. It will seem that the program reads G54 and advances to the next Block.
    Regards,
    Bill
    Jun 2011
    New Jersey
    793
    460
    301
    Have you checked with Fanuc? I believe it is an option for turning but rare. Fanuc options must be purchased and loaded like Okuma does. Gone are the days of merely flipping a parameter.
    Feb 2006
    Republic of Texas
    2,425
    916.2 ymmv
    Jan 2014
    Washington
    4,046
    760
    2135
    G54-G59 is available on a 0TC with firmware versions other than 660 and 662.
    Jul 2013
    Indiana
    3,100
    4542
    1582
    A while back I posted these pictures of our Johnsford lathe with the 0-T control. One on the far right has has the G54 G55 G56 fixture offsets on it. Weather it's a 0-T"C" I don't know?
    Brent
    Geometry Offset on the Lathe Yang ML25A Fanuc O-T
    Jan 2014
    Washington
    4,046
    760
    2135
    Quote Originally Posted by yardbird View Post
    .....Weather it's a 0-T"C" I don't know?
    Hey Brent,
    If you want to know, post up the firmware version and I'll look in my info and see if it shows up.
    Kevin
    Jul 2013
    Indiana
    3,100
    4542
    1582
    Hey Brent,
    Kevin
    Hey Kevin,
    I wouldn't even have any idea where or what to look at to tell you what version it is? Not the first clue? Lol...
    How do you tell what version of firmware it is?
    Brent
  11. #11
    Jan 2014
    Washington
    4,046
    760
    2135
    On the 0 series the firmware number shows on the screen for a moment when you boot the control. Sometimes if the CRT is a bit slow to warm up you won't have a chance to see the number before it is gone. If that happens just turn the control back off, count to 3 and turn it back on. Usually that will let you catch the number.
  12. #12
    Jul 2013
    Indiana
    3,100
    4542
    1582
    Not exactly sure what it is so this is what I saw. It ain't up there long that's for sure. Lol...
    Freaking sideways picture wtf?
    Brent
  13. #13
    Jul 2013
    Indiana
    3,100
    4542
    1582
    Quote Originally Posted by alphonso View Post
    916.2 ymmv
    For what it's worth my 916.2 = 1
    Brent
  14. #14
    Jan 2014
    Washington
    4,046
    760
    2135
    0667 means it is an 0TC-F. The F indicates FAPT which was Fanuc's conversational lathe programming software. Does your machine have conversational?
  15. #15
    Jul 2013
    Indiana
    3,100
    4542
    1582
    No not that I'm aware of. It's a "C" axis lathe but none of the tooling came in with it so we've never used it. I'm almost positive it doesn't but maybe I need to look it over better. Can't imagine where I'd find it I've been all through it.
    Brent
  16. #16
    Jul 2013
    Indiana
    3,100
    4542
    1582
    Can you shut it off by parameter? What I mean is not to load the conversational programming when it boots up at startup? Hell maybe its shut off? The danm thing comes on almost instantly.
    Brent
  17. #17
    Feb 2007
    Aberdeen, UK
    3,306
    1173
    1235
    Mine is a 669. I set 916.2 and lo and behold I now have work offsets. They look exactly like Brent's - hidden behind a toggling softkey. So thanks all for that!
    Next question is, how do they work? There is no Measure soft key like on the Oi, and MZ doesn't work like when setting the work shift. There must be an easier way than calculating the offset and entering it directly?
  18. #18
    Jul 2013
    Indiana
    3,100
    4542
    1582
    On this particular machine that's exactly what I do. I've never got this figured myself. The guy in post 6 has a detailed description on how to use the measure function but I was unsuccessful when tried it on my machine. Maybe I wasn't doing something exactly right? Maybe he'll show back up here?
    Have a look below. Talk about finding a needle in a haystack! Lol
    Brent
    Problem getting my head around work offsets on lathe
  19. #19
    Sep 2010
    Victoria Australia
    3,557
    1396
    Hello gregor,
    If your control has User Macro and you let me know how you're setting Tool Geometry, I can give you a Macro Program for setting the Work-shift Offset value of the Offset of choice.
    Regards,
    Bill
