So this is on a 2008 Fadal 3016FX Per the post title It has a Fanuc OI-MC Control. We've already ran a couple hundred of these parts. Each having three 1/4-20 tapped holes. Swing shift last night all the sudden It starts pulling parts out of the vise while tapping and generally not holding pitch and cobbling up threads. Might tap a couple good holes then go to crap. Unpredictable. Any Ideas here? Is there a way to check that the orientation sensor is functioning properly? Would that even cause the problem? I have two of these machines basically Identical. The only difference I can see is that on the one that is functioning properly. Acts like this right before tapping >> Positions to hole. Spindle orients and stops. Holds position solid until it goes into rigid tap. On the other the same thing except after it orients I can see the spindle rotation drift a bit before going into rigid tap like I said the other is solid, never drifts stays put until it goes into rigid tap.
I know some of you will ask for the code even though we've successfully ran a bunch of parts before this problem. So here It Is. Any help appreciated!
N7G17G80G40G90G49G0
T7M06
( 1/4"-20 CUT TAP )
G90G54
S500M03
G90G0X0.Y.866
G43Z.5H7T1
M08
M29S500
G84G98X0.Y.866Z-.875R.5F25.
X-.75Y-.433
X.75
G0G80Z.5
M09
G91G28Z0.
N7G17G80G40G90G49G0
T7M06
( 1/4"-20 CUT TAP )
G90G54
S500M03
G90G0X0.Y.866
G43Z.5H7T1
M08
M29S500
X-.75Y-.433
X.75
G0G80Z.5
M09
G91G28Z0.
