Hi All,
I just received a 2009 machine with the Renishaw Inspection Plus system in it and the macros. Unfortunately, I did not receive any documentation. The Renishaw library does not appear to have the information on how to use the macros I have. The documentation for OTS and OMP40 are for newer macros starting in the 9900's.
My machine has:
9023 REN EASYSET
9029 BOLT HOLE CIRCLE
9721 REN X DIAM
9722 REN Y DIAM
9723 REN ACT OFFSET
9724 SETTING
9726 REN BASIC MEASURE -2T
9732 REN OFFSET TYPE
9750 REN SETTING
9751 REN_START
9752 REN MEASURE MOVE
9753 REN G31 MOVE
9754 G0 G1 MOVE
9755 DIA SET
9759 REN ERROR MESSAGE
9799 REN SETTING
9801 REN CAL PROBE LENGTH
9802 REN CAL XY OFFSET
9803 REN CAL STYLUS RAD
9810 PROTECTED POSN
9811 XYZ MEASURE
9812 WEB POCKET MEASURE
9814 BORE BOSS MEASURE
9819 PCD BORE BOSS
9850 REN TOOL SELECT
9851 REN LEN SET
9852 REN DIAM SET
9853 REN AUTO SET
9855 REN STLUS CALIBRATION
9856 MANUAL TOOL SETTING
9857 REN TOOL AUTO SET
9858 BROKEN TOOL CYCLE
9859 REN TEMP COMP
I have a basic knowledge to call the programs with variables in the call line but I do not know what the variables should be.
Can someone help please?
Todd
My machine has:
9023 REN EASYSET
9721 REN X DIAM
9722 REN Y DIAM
9723 REN ACT OFFSET
9724 SETTING
9750 REN SETTING
9751 REN_START
9753 REN G31 MOVE
9754 G0 G1 MOVE
9755 DIA SET
9799 REN SETTING
9810 PROTECTED POSN
9811 XYZ MEASURE
9819 PCD BORE BOSS
9851 REN LEN SET
9852 REN DIAM SET
9853 REN AUTO SET
9859 REN TEMP COMP
Todd
