lowCountryCamo
Stainless
- Jan 1, 2012
- Savannah, Georgia, USA
I have a Fanuc 0md Yang mill. And I found a Tsudakoma 4th from HGR minus a motor and internal wires. So I pieced together everything and got it running however after installing the motor cover it won't move and I get the 414 excess position error detected. With the cover off on the table with wires running through the case terminals it will run. I have been round and round with this thing. I nearly pulled it off today and gave up. Just then I think I narrowed it down. When the case is resting on the table grounded it runs. If I isolate it with card board underneath it wont move. How should the motor, case, wire connections be grounded?
Steve Austin
Steve Austin
