Check Parameter #1302 bit 0, should be 1. Also, #1301 bit 7, should be 1.
Paul
Copied from a Fanuc Manual ...
- Stored stroke check 1
Parameters (Nos. 1320, 1321 or Nos. 1326, 1327) set boundary. Outside the area of the set limits is a
forbidden area. The machine tool builder usually sets this area as the maximum stroke.
When the tool enters a forbidden area and an alarm is generated, the tool can be moved in the reverse
direction from which the tool came.
At this time, a signal (overtravel alarm signal) can be output to the PMC if bit 6 (OTS) of parameter No.
1301 is set to 1. In addition, when the tool enters the forbidden area during manual operation, the signal
(overtravel alarm signal) can be output to the PMC without generating the alarm by setting bit 1 (NAL) of
parameter No. 1300 to 1. With this parameter setting, the alarm is generated when the tool enters the
forbidden area during automatic operation.
Hello Paul
Parameter #1301 bit 7 is already set to 1 by mtb
And I set #1302 bit 0 to 1 this morning but it is not working
Nick
Siemens and Okuma can both "pre-check" if a movement will enter a forbidden zone and warn BEFORE the machine actually enters the zone.
As for Fanuc, even on the higher series, I'm not so sure that such a "pre-check" could be done, short of writing a Macro command to look for it.
The question is how useful this feature is. It will not tell you in the beginning of the program that the tool will enter a forbidden zone (I think so. I am not aware). If it halts the program just one block earlier, how does it help? One has to abort the program, and modify it.
Notice
