I've worked in shops before where if you typed in -5 then hit input+ on the wear offset screen, the offset would move by -.0005. This doesn't work at the shop I'm currently at. Is there a parameter that can be changed to enable this? Fanuc Oi series controller. I've already changed #5213 and # 5214 to limit wear offset max and incremental input of wear offsets. Are there any other parameters that you typically like to check and change when a new machine rolls into the shop?
