llf264
Cast Iron
- May 18, 2006
- Ft. Worth, TX
Hi guys, as many of you know, on the face of a Fanuc powermate e drive, there is a switch and button selection that shows a load and a save option, and a little pushbutton to activate that cycle.
Question #1: Does "Load" mean Load memory from drive to card, or does "Load" mean load memory from card to drive?
Question #2: Does "Save" mean Load memory from card to drive, or does "Save" mean load memory from drive to card?
Those two questions should be double checks on each other.
Question #3: What state does the drive need to be in when using this manual method of saving memory from the card to the drive? Powered on, but any other criteria? Example, main control needs to on or off? In Write enable mode for writing from drive to card or not or another mode while reading from the card to memory? Another other little tricks or tricks to make sure I don't bang my head against a wall for a while figuring this out?
I have a card with memory from one machine loaded on it already. Many videos on the internet show how to use a Powermate Pendant to perform this function for two different types of memory, and I hoping to use the manual push-button method which does not have any videos on the net that I have been able to find so far.
Question #4: How about lights? How will I know when the process is under way successfully or complete?
Question #5: If I only have one card, is there a way to capture BOTH types of memory on one card rather than the two card method I see online? What are those two types of memory anyway? If using the manual button method does that do both automatically?
I have attached a pic below of the area in question.
Thanks a ton!!
Thanks a ton!!
